Results 1 to 21 of 21
Thread: v6 vs engine into a v6 vp.
    vp commodore 3.8ltr
    Jul 2006
    melton melbourne vic
    Default v6 vs engine into a v6 vp.
    will a v6 vs engine bolt straight into a v6 vp and would i have to change the computer and loom?
    VP WAGON V6
    Mar 2006
    yes yes and yes... lol I think that there would be a bit more work then a straight swap.. Front wireing loom would need to be changed ide say. You would also need to change gearbox and MAYBE tail shaft.. ummm but other then that it will BOLT up.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    The wiring loom is different yes.. Computer would need to be changed.
    VS has a PCM (Powertrain Control Module) and a BCM (Body Contol Module) as well which the VP does not.
    If its an auto, the VS ran an elecronic gearbox, 4L60E, whilst the VP had the mecanical setup.
    vk calais, vn waggon
    Jun 2006
    easiest way is to run a aftermarket computer
    as u need to change engine\box, body and dash looms,
    alot of work involved as all looms are inverwooven lol
    vn\p run speedo to dash then comp
    vr\s run speedo to comp then dash
    biggest hurdle to get around
    VP Executive R-spec
    Jan 2005
    VN/P Loom, VN/P computer, theft disabled VR tune . (I'm going to assume the gearbox bolts onto the ecotec OK)
    HATER VP Guest
    HATER VP Guest
    Why not lash out. Put the VS motor and trans in, along with a VS dash. Run full VS wiring.
    Youve got me thinking about my next project. Im putting a Ecotec into my VP V8. My V8 engine is going into a UC Torana hatch. The torri is a unfinished project with a low KM ecotec motor.
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by hatervp
    If its gonna be an auto, I think most people would rather keep that standard 4l60 rather than use the 4l60e transmission out of a VS...The electronic gearbox doesnt shift like the VN/VP gearbox
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Could of saved a heap of trouble and looked up my thread Ecotec into a VP
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    vp commodore 3.8ltr
    Jul 2006
    thanks for the replies ive now saved myself alot of trouble and $$$ so i think i will just put in another vp motor.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Try a VR motor
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by SlickHolden
    Try a VR motor
    Why? Its only an extra 3kw... More hassle as theres still differences in the wiring loom etc.
    Where as the VP engine is a straight drop in
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    VR is a little better internally but.
    I can't believe this i thought the Ecotec was a drop in for the VP I have been building it up for next year and now it's not looking good at all I could cry
    1991_Vn2nV's Avatar
    Mar 2006
    Actually mechanics say the VP engine is the best. The VR has problems with the Fuel Injectors leaking wearing in the pintles or something which then causes a leak.
    The VP followed in 1991 and to date in our opinion is the best Commodore ever released. Even by 2005 standards we very rarely have to do any repairs to these ever reliable units bar general servicing.
  15. #15
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Quote Originally Posted by 1991_Vn2nV
    OK i agree DaVeePee You know one thing out of all the Buick motors i see more VP's that don't sound as loud at the engine, My mates VR Berlina has a very loud engine. Guy down the road has one same as mine, Guy only 7 houses away has the same also, Both of them are quite running engines, Not as quite or anywhere near a Ecotec but very quite for Buick's.
  16. #16
    1991_Vn2nV's Avatar
    Mar 2006
    The sound the Buicks do make aint too bad either Better than the Ecotec which sounds like a freakin blender on steroids
  17. #17
    VP Executive R-spec
    Jan 2005
    Ecotecs in a VY sound ace at peak revs (dual cats / semi dual zoorst makes all the difference)
  18. #18
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by greenfoam
    Interesting... I've only driven commodores up to VX and they all had that blender on steroids sound.
  19. #19
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    They do go alright the VY's, I have been in a VYII and they seem every bit as fast as a VS. They would kill a VT.
  20. #20
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    the vp body is also lighter then what the vr is so be a little faster again but i agree, alot of stuffin around
    Current: My Ride
    VY Series 2 Berlina, Leather
    Previous: Ride 2
    VR Executive, 5 Speed Manual, Ecotec 3.8
  21. #21
    VP WAGON V6
    Mar 2006
    if you have the ecotec just make it fit, Its not that hard to do. Just a little time consuming and maybe a fw extra dollars.
  1. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  2. engine light, engine cut out
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2007, 12:10 AM
  3. Engine + engine bay colours?
    By traindriver in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-05-2006, 02:06 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine stalls and engine light comes on.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:01 PM
