Results 1 to 4 of 4
Thread: L3 Cluster HELP!!!
    VN S2/ Original XRGT
    Jun 2006
    Default L3 Cluster HELP!!!
    My speedo and tacho are'nt working on my L3 cluster i just finnished installing it into my excecutive would these things not be working due to the fact that i have not yet joined the yellow wire to my ecu?.If not please help has anybody had this problem before?.
    Jun 2006
    I've taken it for a drive this morning and the speedo works now after a good old tap on the cluster but still no tacho.
    HATER VP Guest
    Have you got the dash from a V8, and fitted it to a V6 or vise versa??
    Tachos are different between the 2 engine sizes and will not work correctly if the wrong one is fitted.
    Jun 2006
    The L3 cluster i brought was advertised as a V6 cluster how do i tell the diferance between a v8 one and a v6 one?
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  3. Vn cluster
    By redlion05 in forum Electrical Wiring / Questions
    Last Post: 18-10-2006, 10:29 AM
  4. led cluster
    By fu2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2005, 02:57 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
