Results 1 to 3 of 3
Thread: Brake light issue
    VN Calais
    Feb 2006
    GolD Coast
    Post Brake light issue
    Hey all, i've got an issue with my RH Tailight.
    1. when i don't have my headlights/parkers all my brake lights work fine.
    2. with lights on all my brake parker lights work, then when i hit the pedal the right one goes off and left and centre light work,
    its been confusing me for sometime now, i'm not spending any money on fixing it, but if worse comes to worse, i was wandering if i could just cross the wiring loom from the LH side to the RH Side, what do you all think?
    :b:
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    You will probably need a new wiring harness or the RH tail light man.
    But before you do, Check all the earths though and check the globe, make sure its the right kind of globe (double filament) and that the filaments are not touching or anything. Lastly check the wires going to the globe etc, make sure all the wiring is fine and that there is no short in loose wires.
    A harness will cost you about $30. Most of them have corroded by this age due to the leaking habits of VN boots and tail lights.
    1991_Vn2nV's Avatar
    Mar 2006
    Oh and try giving the gobe socket etc. a spray with Penetrene, it might help clean up any corrosion if there is some.
  1. vs brake issue *look*
    By gee38l in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-04-2007, 07:48 PM
  2. VR Acclaim brake issue
    By avon57 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-02-2006, 03:42 PM
  3. Brake Issue
    By Haze SS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-10-2005, 01:35 PM
  4. another light issue!
    By 5spdVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2005, 09:39 PM
  5. Introduction & Possible Brake Issue
    By Camotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-05-2005, 02:18 AM
