Results 1 to 3 of 3
Thread: Will a tacho from a L2 fit L3 Cluster
    VN S2/ Original XRGT
    Jun 2006
    Default Will a tacho from a L2 fit L3 Cluster
    Ok i just installed my L3 cluster and my speedo or tacho were not working but after giving the cluster a bit of a whack the speedo works fine now.But my tacho is not working still i'm gonna pull my cluster apart and have a look but if it still dont work can i just put the inside part of the tacho [tachomotor] from a L2 cluster into a L3? are they the same or differant?.I've heard that after about 250 thou on the L3 cluster the speedo and tacho stop working but my L3 cluster has only done 180thou.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    take it to a speedo shop, where are u located?? if your in melbourne they'res a really good shop in ringwood, its called ringwood speedo's
    if it can be fixed, they can fix it... they can also test if the cluster is working, it may not be hte cluster, its happened to me before, turned out to be the wiring loom
    Anyway
    Ringwood Speedometer service
    9874 2260
    they tested my cluster for free, but otherwise, i dont think it will fit, as the L3 clustershave a wider spacer for the trip computer
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    check the circuit board in the cluster for dry or cracked solder joints. very common thing.
  1. Changing a speedo in a VN tacho cluster
    By savage1987 in forum Holden Commodore How-To's
    Last Post: 05-04-2008, 10:42 PM
  2. need help asp instrument cluster with tacho
    By sick_vk253 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 09-10-2006, 08:03 PM
  3. vs tacho dash cluster into a vp??
    By Matt_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-09-2006, 12:52 PM
  4. level 2 tacho cluster problems
    By nathans1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2006, 09:11 PM
  5. vl tacho cluster into sl vl
    By creig451 in forum Electrical Wiring / Questions
    Last Post: 05-09-2004, 02:09 PM
