Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: Few Probs with me vn wags
    Phoenix21's Avatar
    Phoenix21 is offline Donating Member
    93 VR, 97 VT, 95 Statesman
    Feb 2006
    Crime bourne, Vic :P
    Default Few Probs with me vn wags
    First off my water pump is screwed it keeps leaking water just wanted to know if thats hard to change im ganna buy the part in the next cople of days
    2nd when im driving now days im getting a lot of rattling coming from my boot kinda like the boot isn't closed right any ideas what i should do about that
    3rd it has been idleing pritty ruffly l8tly i'd take a video and show ya but i don't know how to put it on the net and make the file smaller, when i start the car and im out side of it, it kinda sounds like it backfiring but quitely
    thanks for your help cheers Matt
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by Phoenix21
    Water pump isnt too bad. Just disconnect the battery as usual, remove the pump pulley bolts and disconnect the drive belt. Drain the cooling system. Remove the pulley from the water pump and then remove the water pump bolt and water pump from the engine as well.
    You'll have to replace the water pump gasket too. You're spose to apply Permatex Lock Nut to the threads of each water pump bolt as well. Then refill the cooling system and put the drive belt back and run the car and check for coolant leaks to make sure its all ok. Oh and re-connect the battery after you refill the cooling system.
    I also have recently noticed a rattling from my boot which I hear when I go over bumps and when my subs are on now too. Im not sure what it is yet though.... But it never used to rattle.
    Also you may have a hole in your exhaust or something. Is the noise coming from the back of the exhaust or is the noise coming from halfway or something?
    Phoenix21's Avatar
    Feb 2006
    hey the noise from my boot is happening every time i go over a bump and it aint a quite noise its really loud and the noise from my exhaust is about half way
    1991_Vn2nV's Avatar
    Mar 2006
    Well for the noise from your boot, check your number plate and make sure its screwed down tightly and is not vibrating when you go over the bump. Check theres nothing loose in the spare wheel well etc. as well.
    Perhaps try taking your car to an exhaust place and asking what they think it is. They should have a quick listen and look for free and then advise you on the situation. It sounds like there is a hole in the cat or the exhaust pipe somewhere.
    VP WAGON V6
    Mar 2006
    noise could also be your rear whiper motor has come loose.. Got subs, cuase my subs rattled mine out of place. hahaha.. Could be a broken zorst mount. Just get under and have a look
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by commy92
    The sedans dont have a rear wiper motor though. Although my car does have all the wiring for rear wipers and washers...not sure where the wiring stops though....
    Phoenix21's Avatar
    Feb 2006
    me cars a wagon i checked the wiper motor today thats fine it won't move at all i havn't got me sub in my car at the moment my xsort was missing a clip but that been fixed but yet there is still noise coming from the boot oh yer and ive check the number plate tight as can be
    Phoenix21's Avatar
    Feb 2006
    oh yer 1 more prob i just thort of my heater dosn't work at all all i get is fezzing cold air thanks
    1991_Vn2nV's Avatar
    Mar 2006
    First off for the boot noise. Perhaps try putting your sub in the boot and turning it on...then tracing the noise with your ears til you find where abouts its coming from.
    As for the heater, is it just the heater or does the A/C not work either?
    Remember it takes a while to warm the air up on cold mornings, takes mine 15 minutes or so.
    Phoenix21's Avatar
    Feb 2006
    nope a/c not going either i remeber in summer last year i was getting warm air ive had me heating running for like 15mins or so and still nothing /
    yer i'll try what ya said with the sub tomorrow
    1991_Vn2nV's Avatar
    Mar 2006
    Well check the temperature guage while you're driving..make sure the car is running at a normal temperature.
    The thermostat could be faulty.
    Other than that...Make sure the temperature selector is working. Make sure the rod is connected behind it.
    N while the engine is running make sure the heater valve is working when you put the temperature control all the way to cold. I had trouble with the heater valve on my car.
    Hmm tea time...i will think about it over tea and get back to u with any other possibilities.
    Phoenix21's Avatar
    Feb 2006
    1991_Vn2nV's Avatar
    Mar 2006
    I had a think but thats all I could come up with. Give an air con place a call if all else fails, just get em to find the prob which should only take half an hour then fix it yourself = cheaper
    Best of luck with it all man
    Phoenix21's Avatar
    Feb 2006
  15. #15
    VP WAGON V6
    Mar 2006
    my wags does the same with the air. except i get a bit of warm air. just no ircon
  16. #16
    1991_Vn2nV's Avatar
    Mar 2006
    Does the fan turn on when you turn the air on button on? If not its an electrical problem.
    Also it might just need a re-gas. When they get low on gas the low pressure switch stops the air con from working, even if theres some left.
  17. #17
    Phoenix21's Avatar
    Feb 2006
  18. #18
    Vp Executive Wagon
    May 2006
    Sydney, Northern Beaches
    my heater and air con wont stop running even when i turn off the all of the switches... is this normal?
  19. #19
    Phoenix21's Avatar
    Feb 2006
    not by the sounds of it god my car is full of problem i might end up selling it ok a normal person with a normal car would get about 400 / 500ks out of a full tank of petrol im getting just over 250 max 300 why would that be
  20. #20
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by james_and_ his_VS
    Hmm depends what you mean. They still let some air in so if its set to hot with everything turned off it will still bring some hot air into the car.
    But the fan should not be going. If the fans going then theres an electrical problem and you'll need to get it checked.
  21. #21
    1991_Vn2nV's Avatar
    Mar 2006
    Probably the o2/oxygen sensor would be a cause. They're meant to be replaced every 100,000km's atleast but very few people do...
    Other possibiities in order of what I think is most likely are:
    Faulty thermostat or coolant temperature sensor
    Could just be your spark plugs or incorrectly gapped spark plugs
    Faulty ignition leads
    Faulty air flow sensor
    A leak in the fuel system (generally in the fuel injectors, especially VR)
    vacuum leak
    Incorrect fuel pressure
    It could be a mixture of things...but definitely the o2 sensor should be replaced, and check your leads and plugs! Thermostat as it could have been a problem for the heater also is high on the list.
  22. #22
    Phoenix21's Avatar
    Feb 2006
  23. #23
    VP WAGON V6
    Mar 2006
    my aircon switch isnt in the car at the moment. BUT when you plug it in and turn it on the clutch doesnt dissangage on the compressor and it just free spins.
  24. #24
    1991_Vn2nV's Avatar
    Mar 2006
    you might wanna get that checked I bet an air con place would know the problem straight away
  25. #25
    Phoenix21's Avatar
    Feb 2006
    how hard is it to change the thermostat and where about should i buy 1 from
  1. sleeper vl wags
    By JUDDO13 in forum General
    Last Post: 15-04-2007, 11:21 PM
  2. wags
    By commy92 in forum VN - VP - VG - VQ
    Last Post: 23-11-2006, 02:15 PM
  3. my vp wags
    Last Post: 30-05-2006, 08:28 PM
  4. my new vk wags
    By pier_one in forum VB - VC - VH - VK
    Last Post: 07-02-2006, 06:57 PM
  5. My VT Wags - A work in progress
    By ciaranvt in forum VT - VX - VU - WH - V2
    Last Post: 18-01-2006, 10:52 AM
