Results 1 to 24 of 24
Thread: Are these Shorten Monroe GT Gas shocks?
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Default Are these Shorten Monroe GT Gas shocks?
    Here are some pcitures, Took them almost 2 week to send them out and something feels wrong about them.
    Has anyone got any for there VN-VP??
    Shorten Monroe GT Gas shocks.
    Attached Thumbnails Attached Thumbnails Are these Shorten Monroe GT Gas shocks?-picture-001.jpg   Are these Shorten Monroe GT Gas shocks?-picture-002.jpg   Are these Shorten Monroe GT Gas shocks?-picture-003.jpg
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    VP WAGON V6
    Mar 2006
    looks like them to me. I cant compaire them with mine cause mine are for a wagon. But they look like short shocks.
    90 VN SS 5speed, '90 VN Calais 5speed
    Jan 2006
    stanthorpe, qld
    yep they are.
    their the same as the ones in my wagon
    Attached Thumbnails Attached Thumbnails Are these Shorten Monroe GT Gas shocks?-pict1628.jpg
    Adam
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I was just a little worried as it took so long and i got nothing other then the box. I was a little cheesed off, The first thing i ordered was the shocks, Done the springs 3 days later and now it's a whole week after that and they finally arrived, I could have had them fitted twice when doing the springs and even the exhaust.
    thanks guys
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    when you take a stock shock out, the short shocks will be around an inch shorter from memory.
    and just checked the monroe site, its the right part number.
    Jan 2006
    stanthorpe, qld
    if u cant find the part number on the monroe site i might still have the box from my shocks. i will check tomorrow if u want, but it might be different from sedan to wagon im not sure
    Adam
    hakhawk's Avatar
    Jan 2005
    and just for you adam, wagon and sedan are different, as they have different mounting points so are different lengths.
    Jan 2006
    stanthorpe, qld
    hakhawk's Avatar
    Jan 2005
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Thanks for the Pic Adam.
    Thanks Hakhawk for the info.
    I can see what you mean about them mounting different on the rear, I didn't know they sat like that on a angle on the wagon's.
    Can anyone give me me some tips on sticking them on. Should i grab some ramps reverse up and just take them off one by one is it that easy? O do i need to raise the car in anyway because they are shorten?.
    hakhawk's Avatar
    Jan 2005
    you will need to jack the car up so the diff has no pressure on it(not on ramps, dont jack up the diff itself).
    then just unbolt the old shocks and stick the new ones in.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    So just get the wheels off the ground, Is it OK to go one side at a time?.
    Dam i need a jack
    hakhawk's Avatar
    Jan 2005
    mm, not sure how youd go with one side at a time to be honest. me n dad did both sides at the same time. im sure someone else will know, otherwise, jack up one side and see if you can get the shock off.
  15. #15
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I was a bit worried about jacking it up then jumping in the boot to loosen the bolt in there i might drop the car I have that type of luck to
    Actually my mate might have stands i could borrow get the rear up in one shot
  16. #16
    hakhawk's Avatar
    Jan 2005
  17. #17
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Might wait till the weekend now, Got to go to cranbourne to grab a Calais garnish, But I'll have Camera in hand for the VE look out. This time i got a digital camera couple of days late but
  18. #18
    Jan 2006
    stanthorpe, qld
    i did mine 1 at a time!
    i put superlow kings and the shortened shocks in 1 side at a time. just support the car on stands and u will be fine. i didnt have any troubles
    Adam
  19. #19
    VN Commodore
    Feb 2006
    shortened shocks should be more than an inch shorter. i have a set of pedders lowered shocks in the back on my car are they would be at least 3 inch's shorter
    i reckon 1 side at a time is a lot easier too.
  20. #20
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I'll go one at a time but I'm thinking can i jump in the boot and undo the bolt nut in there before a raise the car up?. Not to confident of jumping in the boot when it's up off the ground, Bad memories
  21. #21
    Jan 2006
    stanthorpe, qld
    Quote Originally Posted by SlickHolden
    i dont see why not.
    Adam
  22. #22
    Jan 2006
    stanthorpe, qld
    oh and just incase u didnt know you will need a pair of vice grips to hold onto the bolt part of the shock(the bit that goes through the floor)to stop the shock from spinning when you undo it
    Adam
  23. #23
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    OH yes thanks for that you twigged my mind I remember my brother doing that in his EF, Aren't they lucky back seat job
  24. #24
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    My brother and i changed the shocks yesterday, When the olds were removed they were shorter then the Monroe ones. They were pedders sports Ryder's is that normal?
    But the rear feels good I'm pretty happy
  1. Rear Lowered Monroe GT IRS VR-VS Shocks Including Statesman and Calais
    By HIROLLA in forum Parts And Other Items For Sale
    Last Post: 04-05-2007, 08:03 PM
  2. WTB Pacemaker extractors and shorten shocks
    By ssmate in forum Swap / Wanted to Buy / Trade
    Last Post: 21-02-2007, 06:54 PM
  3. Need help: Which Monroe Shocks?
    By angelo.vs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-06-2006, 12:08 AM
  4. monroe shocks
    By aussieboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-06-2006, 12:51 PM
  5. Shorten VT1 Gear Shift - Can it be done?
    By davus in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-01-2006, 05:13 PM
