OK so i bought a new vp and want to put the exhaust system from my vn into it how should i go about doing that?
Kilowatts are like drugs, the more you get, the more you want.
DARA PRIDE!!
Remove exhausts from the cats bak from both cars n do the swap should only take probly an hr maybe 2 if u dont have ramps to do it on....2 bolts for the cat to pipe then a couple rubber rings that hold the muff up...easy job..
yeah thats a pretty easy swap, i got mine off a VB and modifed it to fit, little more work involved, but yeah very simple,
Thats all well and good, providing the VP isnt IRS, if the VP is IRS, it wont fit without modification, if its non-IRS, 2 ramps, and if you can, a pnuematic ratchet, makes it real easy
Only if it is a Calais or Stato would it have IRS.
