Results 1 to 10 of 10
Thread: Saving $$$ with engine flush
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Smile Saving $$$ with engine flush
    Just saved a heap of $$$ by using some engine flush on my 91 VN V8. I changed the oil one day and this horrible noise failed to stop when I fired it up. Souded like a knock from the crank I was told by a spanner man. Crank out regrined.....I felt a bit sick. I was then told to use a flush and it would fix most of the noise. 1 hour later the engine was fine. Save around $1000.00.
    The flush stuff was $15.00
    Hope this helps !! It did for me.
    HATER VP Guest
    What flush did you use??
    I always use Nulon Engine Flush. Will even boost compression, Dissolves sludge in the engine, Frees up piston rings, basicly cleans out the oil system.
    You can buy Stop Smoke which is really good. Not only "Stops Smoke" but also quitens down the engine because it is really thick.
    Nulon are now making engine oils. The guys with VN-VP with over 200km should really be using Shell Older Engine Oil.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    I use Nulon engine flush also.
    I get i slight knocking when the car is warm and driven then stopped, When you go back to it say 10min later it will knock and clonk for 10sec then stop.
    I just say it's old age 300,000km+ old age. But i still use Castrol GTX-2. Never makes a sound when driving it.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    HATER VP Guest
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    Lucky i warm it up before i go anywhere, My mate doesn't and she just done a intake manifold the thinks ticks faster then a Skippy
    88GreenVN's Avatar
    Jun 2006
    Just went to Sprint auto parts and asked for some engine flush. The motor is as quiet as a V8 can be with one muffler. Much better noise than the knock and lifter noise it had developed. I'll give the bloke a 6 pack next time I see him for his advice. The car was only moments away from major overhaul. Some days you are just lucky.
    VXII Exec
    Jan 2006
    NTH Suburbs Melbourne
    You guys do realise Engine flush is diesel, some had a few additives but diesel will do the same job.
    88GreenVN's Avatar
    Jun 2006
    Vz Sv6
    Jul 2005
    Quote Originally Posted by 88GreenVN
    $10? or was that $15
    88GreenVN's Avatar
    Jun 2006
    Well it was...$11.95. Dug around the bin with a stick...Sorry! - and it was Wynnes I think!
  1. Engine oil flush/injector cleaner
    By kmbattle in forum LSx Development and Modification
    Last Post: 01-07-2010, 08:23 PM
  2. daylight saving
    By R0d in forum The Pub
    Last Post: 04-12-2006, 10:53 PM
  3. Life Saving First Aid
    By SLugg in forum Jokes/Humour
    Last Post: 18-04-2006, 11:17 PM
  4. What are you saving up for?
    By Troy711 in forum The Pub
    Last Post: 30-09-2004, 11:28 AM
  5. Drain Engine Coolant For Flush/refill
    By Fatboy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2004, 02:47 PM
