Results 1 to 20 of 20
Thread: Q's about flushing cooling system (I know this has been posted alot but...)
    '91 VN V6 Executive
    Jan 2006
    Question Q's about flushing cooling system (I know this has been posted alot but...)
    I have been trying to get my head around every step before I do it, but from the previous threads I have searched and read through, I am confused on some of the points as there seem to be a million different ways to do it.
    If I put down the steps as I can best understand them (collated from previous threads), could someone clear up or correct me on the areas I have got wrong. I am planning on running some cleaner in addition to flushing it completely.
    Steps..
    1. Set heater to hot & pour contents of cleaner into radiator and run engine for 20-30mins and then let cool.
    2. Undo top & bottom hoses from radiator and let it drain out, then put a hose in the bottom hole (of radiator) and flush it up and out with water.
    (now this is where I really start to get confused)
    Do I...
    3a. Remove the thermostat & housing then stick the hose in there and flush it with water. Q: where would the water come out, and is the engine running or not?
    or
    3b. Remove the top & bottom hoses from the engine and flush water through the top hole (and I'm guessing would then come out the bottom hole? and same again, engine running or not?)
    or
    3c. Re-attatch both hoses to radiator & undo heater hose, take off radiator cap and stick the hose in there and flush it that way (I'm guessing water would come out of the hole the heater hose was attatched to?; would that clean the entire engine?)
    In order for the engine side of the clean/flush to be cleaned properly, is that (whichever of those steps) all that would need to be done? I am confused about this whole thing about the block holding something like 3 litres. Now will that 3 litres have been cleaned if the whole system was being flushed with water (flushing the crap out and leaving just clean water)? Or does it need to be drained seperately from the third step?
    If the coolant is a 50/50 mix, then would those 3lt make up part of the 50% water side of the mix?
    For a VN (V6 if its relevant) how much coolant/water can I expect it would hold in total? A guy at the store I bought the coolant from said 8lt total, so to pour 4lt of coolant in and top up with water. Is that correct or not? Also where should I actually pour the coolant into? On the boards I have read to either pour it directly into the radiator or directly into the top hose on the engine, so which one would it be?
    If one of the options for step 3 is correct and thats all I need to do for the cleaning, would I now just pour in the coolant (however much I would need to make 50/50 mix) and then top it up with water until its full?
    I do know that at some point at the end I will have to bleed the air out of the system, its just the steps beforehand I am confused about. With so many different points of view on the board I dont know which one to go with! I know its I'm a pain in the arse as it has been brought up a lot, but I do need to ask for me to get my head around it properly before I am actually confident to do it myself, and I know you guys know are a lot more knowledgeable than me!
    Any help would be wonderful! Thanks muchly, I do hope one day I will be able to return the favor.
    tsimira
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    Hi, i can help a little bit
    3a- do it this way, motor off. the water will come out of the bottom radiater hose.
    3b-dont do this. if you did it this way the thermostat will stop water from getting in.
    3c-leave the thermo stat and top radiater hose off. not sure how the hoses run on vn. i would undo both hoses to the heater and flush out with water.Put the heater hoses on.
    Now you have the engine and heater cean you should be good to top back up.
    I put my coolant in slowly so that when iut starts to come up to the thermostat level i can see it. Once i can see it, i put the thermostat baqck in and put the top hose back on.
    I then start the motor and put the remaining coolant in.
    If you put the coolant in slowly the engine should get to operating temp and the thermostat should open and the air will self bleed.
    The manual says they take 10 L of water so put 5L of coolant in first then top up with water.
    Hope you can understand what i've said. I am rushing this before work. Cheers
    My00 Wrx 240kwatw
    Apr 2005
    Oh god. such an easy job made soo hard!
    THere are many ways to do this, this is how i do mine.. done it on my mums VN too. Never had a problem.
    Ok
    Step 1: Turn your Engine off. Make sure the car has cooled for at least 30minutes or suffer hot coolant on your hands :P
    Step 2: Take the Top and bottom hose off, the water will come out.
    Step 3: Stick your garden hose in the top of the radiator where you took the top hose off. Flush the radiator out. The water will flow out the bottom.
    Step 4: Stick the garden hose in the top hose, and the water will either flow through the whole system and come out the bottom hose, or it will come back at you due to the thermostat. If it comes back at you, its a good sign, your thermostat is closed like it should be.
    Step 5: Now once you have flushed out the system, simply put the top and bottom hose back on and fill the radiator up with new coolant. I asually get about 5L in it, then a little more but i just put water.
    Step 6: Once its all put back on, leave the radiator cap off, or the cap on your surge tank, and start the car. Let it idle for 5-10minutes to the thermostat opens and you will notice once it opens, the water will flow down and you will have to add more coolant. Do this to its full, then simply put the cap back on and you are done for now.
    Step 7: Next day: Once you have used your car for a bit, wait till its cooled down and check the level in your radiator, if there is more room for coolant. top it up some more.
    You might even have a little screw near the thermostat, since you have a series 2 engine. You can use this to bleed the air out of the system.
    Hope this helps
    SMIT's Avatar
    SMIT is offline Donating Member
    VT C2R TURBO 5SP + CRUNCH VE SSV 6SP
    Aug 2005
    Mornington Peninsula, Victoria
    maginoodle's Avatar
    Apr 2006
    Quote Originally Posted by kinkbike_rider
    Would this be basically the same process for a VT, any changes?
    pretty much the same for all cars except volkswagons (they are air cooled)
    '91 VN V6 Executive
    Jan 2006
    Quote Originally Posted by maginoodle
    Thanks for the reply, it didnt even occur to me to look at the manual re: capacity, just looked in mine and it says 10lt too. Just a couple of further questions, 3b is obviously not the way to go, but would I have to do both 3a & 3c, or will just doing 3a clean out the heater aswell? Also, do you put your coolant into the radiator or directly into the engine? (and if the latter, in where do you pour it?)
    Quote Originally Posted by VNPOWER
    Ok
    *snip*
    *snip*
    Thanks for your reply also. Its not that I think its a hard job exactly, I just like to know exactly what I am doing with each step, and what is going on when I do it. With things I have no experience with I dont like to make any assumptions incase I bugger it up royally, and because what I have read differs so much I had to ask! Its like they say, its always easy once you know how lol
    One question for you though, if I flushed it through the top hose and the thermostat is closed so the water comes back at me, does that mean the water hasnt circulated throughout the entire system? Would removing the thermostat stop that being a problem?
    Once again thankyou both for your help!
    tsimira
    My00 Wrx 240kwatw
    Apr 2005
    Quote Originally Posted by tsimira
    tsimira
    If its splashes back at you, dont worry about it. I wouldnt bother taking the thermostat out, too much work for nothing. Dont worry about flushing out the system.
    '91 VN V6 Executive
    Jan 2006
    err??
    It really does need to be cleaned as I dont think the guy who gave me the car had done it for a long time so whatever is running through the system looks pretty bad. I just want to be sure of what I am doing beforehand, I dont wanna be like almost every guy I know; winging it and then realising halfway through they have no idea what they are doing lol
    tsimira
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    something to keep in mind....DONT, release coolant from a warm engine, unless you want to crack your block.
    leave it for at least a few hours before you flush the system, the sudden temperature change can crack the engine block otherwise.
    maginoodle's Avatar
    Apr 2006
    Hi, I am not to sure what series vn yours is. Series 1 has the thermostat at the back of the motor.I would leave them on and just flush the radiater and heater.
    I would then fill the radiater up with water only, then go for a drive to get the thermostat open. Then re-flush everything and then top up with coolant and water.
    If yours is a series 2 i the thermostat is at the front of the motor. I would remove the thermostat and flush the motor out and the heater. I would then put the heater hoses back on and the bottom radiater hose. Then put the coolant into the radiater, watching the level at the thermostat hole. When it gets near the top of the thermostat hole, put the thermostat back in and put the top radiater hose on. Then top up coolant.
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    err??
    tsimira
    Awww, you're no fun Yeah, if ya wanna flush it completely, then remove the thermostat and chuck the hose in there, might wanna have a new thermostat housing gasket to chuck on, hell might as well replace the thermostat itself while you're at it. If you don't want to remove the thermostat there is another option. Just drain the system, fill it with plain water and take it for a run, drain, refill and repeat till the water comes out clear. It's dodgy but it has worked for me in the past.
    PS. Just re-read your first post. Please don't run your engine with the cooling system in pieces/drained, that just wouldn't be cool :-)
    '91 VN V6 Executive
    Jan 2006
    Well I did it today and it was pretty straightforward (thanks to everyone for clearing it up for me) I pretty much knew not to run the engine during the cleaning process, I just wast to double check as it was either something I read or something someone told me they mentioned running the engine so I had to be sure hehe
    The engine itself wasnt too dirty, it was mainly the radiator, a lot of sludge came out but didnt take long to clean out. To maginoodle, I have a series 2 engine so I took the thermostat off and did it that way, was a rather painless procedure really.
    Only downside was I forgot to bring the thermostat gasket with me (I did it at my folks place as I have no decent area to do it at home) so its leaking a bit from there, but I'll just put the new one on tomorrow and should be fine. If I can be bothered I'll take a walk to the car parts place and get a new thermostat, but its working alright so should be able to leave it for now if I dont.
    Thanks to everyone for your help, I'm slowly learning whats what with this car (well any car for that matter) lol and very gradually as I read through the manual more of it actually makes sense Dont think I could have done it without all your help (dont have anyone close by that actually knows anything about cars, and what they do know I'm not so sure about)
    Thanks all again, barring any trouble tomorrow changing the gasket, I can say a job easily done!
    tsimira
    maginoodle's Avatar
    Apr 2006
    congrats on a job well done then.
    its amazing what anyone can do when they have a go.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Well done, and thanks for making this thread ^^ I've been thinking about giving my radiator a good flush for a while now. The stuff in the overflow looks like sewerage. Not good /o\
    The 1972 HQ Kingswood
  15. #15
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    tsimira
    It's great when things go smoothly isn't it? Good to see more people getting into maintaining their own cars, not enough people do these days.
  16. #16
    Jasoniumh's Avatar
    Jasoniumh is offline Its a dogs life
    VP Commodore Executive 3.8
    Aug 2007
    Default Straight from the manual
    commodore v6 91-93
    To drain and refill.
    This engine is equipped with an air bleeder valve. The valve is used when refilling coolant using the manufacturers special tool AU425. It is not necessary to open the valve when refilling the cooling system using the procedure below.
    (1) Set the heater controls to the hot position.
    (2) Position a container under the cylinder block drain plugs and remove the radiator cap. The drain plugs are located low down on each side of the cylinder block. (edit: between the welsh plugs)
    (3) Remove the cylinder block drain plugs, Disconnect the lower radiator hose and drain the coolant into the container.
    (4) When the coolant has drained, Clean the cylinder block drain plugs, apply Loctite242 or equivalent to the threads and tighten the drain plugs securely. Connect the lower radiator hose.
    (5) Mix approximately six litres of the specified coolant with an equal quantity of clean water.
    (6) Disconnect the top radiator hose from the engine coolant outlet and hold the hose vertical.
    (7) Fill the radiator with the coolant mixture and install the radiator cap.
    (8) Continue to pour coolant into the open end of the top radiator hose until coolant flows from the engine coolant outlet. (comes out where the thermostat is)
    (9) Place three holden/Toyota M40124 cooling system pellets into the top radiator hose. Quickly connect the hose to the engine coolant outlet to prevent excessive coolant loss ensuring that the pellets are not displaced. Tighten the hose clip securely.
    NOTE : It is only necessary to add the pellets if the coolant system has been completely drained.
    (10) Fill the reserve tank to approximately 25 mm above the maximum mark and install the reserve tank cap.
    (11) Start and run the engine for 20 minutes to dissolve the pellets and purge any air that may be trapped in the cylinder head. Check the coolant level (and top up if necessary).
    I did this to the letter, no probs.
  17. #17
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    how did you remove the welsh plugs without removing the manifolds?
    aZK.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  18. #18
    Jasoniumh's Avatar
    Aug 2007
    Welsh plugs? Cylinder block drain plugs. They are between the Welsh plugs.
  19. #19
    1993 Series II VP Calais
    Sep 2006
    how did you get to the cylinder drain plugs??? i've tried to get them off, but there's no way anything will fit in behind the exhaust manifolds.
    And did you really go out and buy those coolant pellet things?? I'm pretty sure even Holden recommends not using those things anymore :P
  20. #20
    VE SS SPORTSWAGON
    Jan 2006
    Warwick
    Quote Originally Posted by Cogez View Post
    correct. holden have told me that they dont use the pellets caus its turns the water brown, and sludgy.
  1. Flushing the system out
    By cunningvys in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-10-2007, 09:38 PM
  2. Problem Flushing the Cooling System
    By VT Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2007, 01:38 PM
  3. Flushing the cooling system
    By Dayvo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2006, 08:27 PM
  4. Flushing my cooling system
    By Bush VB in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 26-08-2005, 02:17 PM
  5. Flushing my cooling system
    Last Post: 26-08-2005, 12:45 PM
