Results 1 to 5 of 5
Thread: Engine Overheating
    VY SS 02, Kawasaki ZZR-600
    Mar 2006
    Default Engine Overheating
    Hi guys,
    I have recently been having the problem of the engine overheating while stopped at the lights. Before this happened the temperature gauge wouldn't get above half when at the lights and now it gets to quite dangerous levels where the temperature warning light is going off.
    I had not done anything to the car before this started happening (Except for fiddling with power windows). Anyhow, what I have done is top up the engine oil as I noticed that it was getting a little low (just above the fill line) and there was no difference. I got told to check to see if the radiator cooling fan was working and that works.
    Any help on this would be great guys, as I don't want to take it to a mechanic and pay them hundres just to tell me what the problem is
    Anyway,
    Thanks guys
    daza
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Mine used to do that so I took it to the radiator place after I worked on it a bit. Turned out to be a partially blocked radiator and a jammed thermostat. The thermostat would be my first port of call. $15 bucks and it's an easy job... on a series 2. Series 1 VN is a bit tricky.
    Life's Grouse in Frankston South!
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Well a low oil level would contribute, but as thats already checked and the fan is working, i've made two lists, first list is things you can check and cross off the list before it goes to a mechanic, second list is things that could be faulty and require replacing.
    First: Things to Check:
    1.) Make sure there is the right amount of coolant and that its good coolant, not just cheap stuff or water.
    2.) Next thing to check is take the radiator cap off and make sure there is no bubbles in the coolant/radiator. If there is you might have a cracked head/leaking head gasket.
    3.) Check the level of coolant in not only the overflow bottle, but also under the radiator cap. If the coolant level is low under the radiator cap theres a problem with coolant circulation, perhaps a blockage in the radiator.
    3.) Check the Thermostat as fazz said, or grab a new one for $15.
    Secondly, Things that could be faulty/need replacing:
    1.) Blocked air passage in the radiator core which means take it to the radiator joint so they can clear it or replace the radiator if the core itself is stuffed.
    2.) Water pump.
    3.) Last resort, Could possibly just be the temperature guage that is faulty or the temperature sender... But go to a radiator place first to make sure the cooling system is fine.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    well, i cant add too much to whats already been said...but another thing to look at is the plastic fixtures which connect the hoses up to the radiator.
    they tend to get hair-line cracks which are hard to spot.
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    is it losing coolant?
  1. VP V6 Overheating AGAIN!!!!!
    By Cobez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2010, 08:18 PM
  2. Temp gauge red hot / engine NOT overheating??
    Last Post: 02-10-2007, 07:00 PM
  3. overheating? engine light - not good...
    By jolly_97 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-01-2007, 09:01 PM
  4. engine overheating?
    By fullaaa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2006, 02:04 PM
  5. Engine Overheating
    By noddy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2004, 09:44 AM
