Well im able to get my hands on a cheap Standard VU SS Full Exaust(including cat) for $150
Now i know the exaust pipes are off no use, But will the CAT be enough since my next upgrade will be a cat back.
So just wondering if the Cat and possibly anything else is worth keeping.
ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
Being a SS they run a twin cat system, so you can either run twin cats on your car (extra $$$) or sell the second cat off and recoup some money.Originally Posted by anton1o
Sounds good to me!
AirStrike![]()
Selling FG G6E Turbo and buying a N/A Supra
The standard cat on VN's are fine for cat back 2.5 inch systems, as the internal diamter of the stock cat is 2.5" itself. Its not really worth upgrading the cat to a hi-flow unless the exhaust is larger than 2.5".
Why is that? You can have to identically sized cats that both flow totally different figures. The VN cats being a fairly early design (only the second commo to have em) dont flow all that well compared to a LS1 unit.Originally Posted by 1991_Vn2nV
AirStrike![]()
But is it worth the money for slightly better flow? And 100% flow isnt the best combination either.Originally Posted by AirStrike
After 15+ years I wouldnt think the cat would b doing all that much anyway?
Hrmm, so its not really worth it then for me to cut it up and try and sell off a 2nd cat for even 50$
In my opinion no, but see what Airstike says about the catOriginally Posted by anton1o
You summed it up correctly...........its doing nothing! That could be a $10,000 EPA fine, plus if all the guts have broken down the flow rate drops off.Originally Posted by 1991_Vn2nV
Me personally would get it and get a twin into single exhaust system.
AirStrike![]()
The fine only stands if the cat is deliberately gutted or tampered with. So it would be risking a defect and small fine if anything. But Regency never tested my exhaust when I went through there.Originally Posted by AirStrike
