Results 1 to 2 of 2
Thread: Cant flash highbeams since L3 luster con
    VN S2/ Original XRGT
    Jun 2006
    Default Cant flash highbeams since L3 luster con
    I just did a L3 cluster conversion and when my headlights are turned on my highbeams work no problem. But when their turned off and i try to just flash my highbeams buy pulling the indecator stalk back nothing happens. The high beams dont work has any one had this problem before or does anyone know what it could be?
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    it mayb stalk related... or a loose wire. Id say it has nothing to do with the l3 cluster. Maybe wrong. Did it work before?
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
  1. headlights flash on their own
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 13-07-2006, 06:32 PM
  2. USB flash input
    By jazzfan in forum Car Audio
    Last Post: 20-03-2006, 02:52 PM
  3. highbeams stuck on
    By thestash_16 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-02-2006, 09:05 PM
  4. VT ABS and Highbeams
    By vinnywelsh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-06-2005, 01:22 PM
  5. VP blinker flash
    By vpwgn in forum Electrical Wiring / Questions
    Last Post: 01-01-2005, 11:23 PM
