Results 1 to 13 of 13
Thread: VP sounds to REV HIGH
    ir8prim8 Guest
    Exclamation VP sounds to REV HIGH
    My 95 VP revs high all the time and i strugule to get 300km to a tank. a bloke at work thinks that the someone might have changed the computer chip in it.
    if it has been chipped how do i tell and if it hasent how do i fix the econmey and the high reving.
    all help is greatly apreciated
    Jun 2005
    95 VP? so is it a VR/S or VP?
    just take out the memcal i guess, and see if it has any different labels on it
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    ir8prim8 Guest
    Sorry Bud typoed its a 92" my bad
    and it has only just had a service...
    Please Explane
    Jun 2005
    remove your left hand side kick panel. your ECU is behind that. unplug it and remove the two screws. using a socket tool, remove the two screws on each side of it. remove the metal cover and you will see youre memcal. if there is no label or anything on the blue memcal, try removing the blue cover and see if there is any label on the chips.
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    you say it revs high...how so?...at idle what does it rev at once the revs stablise? when on a highway doing say 100k's/hr what does it rev at?
    when did it start revving too high?
    it could be as simple at the throttle cable being too tight.....
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Quote Originally Posted by sircruisealotVS
    Id go with them, See what rev's your getting at Idle,60kmh,100kmh then we can determine something happening..
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    I'd agree with that^^^. Having a car chipped can't make it rev higher than it did before at a certain speed. Is it auto or manual?
    ir8prim8 Guest
    The car is an Auto..
    the car is booked in for a service in the next couple weeks and i realy need to know wat to the the mechanic what to look at for me.
    The car mainly revs high when the car changes gear.(even whilst going easy on the gas). Compairing my car to most others i have been in it dose not rev higher than them whilst doing 60 or 100.(dosent have a tacko(the reason why i said sounds))
    one thing i did notice was that on occation when the car ghanged gear there is a slip of power to the wheels. and the car shrugs when it puts it into the next gear.
    jules's Avatar
    pimpin
    Dec 2003
    that's clearly the transmission then. ask the mechanic to have a look at it. it slips when there is not enough hydraulic pressure to engage the clutch packs properly. you can get the fluid/filter changed, this will sometimes fix it. but unfortunately it's sometimes an early sign of terminal problems (don't i know it...)
    ir8prim8 Guest
    Shortstuff's Avatar
    1995 VR II V6 Wagon
    May 2006
    Yeah it does sound like a transmission problem. I just had mine serviced which was $110 and it seems to have improved it no end. Plenty of VNs and VPs in the wreckers though if it comes to that!
  1. high pitch squeeling at high speed
    By pr0n in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-02-2008, 09:29 PM
  2. High pitch noise @ high rpm
    By Jesterarts in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2007, 10:00 AM
  3. car engine sounds please
    By Coxy_vs in forum The Pub
    Last Post: 27-05-2006, 02:47 PM
  4. Which supercharger SOUNDS the best??
    By savage1987 in forum V6 Development And Modification
    Last Post: 02-04-2006, 11:27 PM
  5. Sounds Better... Looks Better...
    By jazza21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2004, 12:41 PM
