Results 1 to 5 of 5
Thread: VP Dash Equipment
    ir8prim8 Guest
    Default VP Dash Equipment
    My odomiter and my trip meeter have stoped clocking over and my fule and rtemp gages are always reading incorectily or not reading without a thump.
    is it possible to fix all the equitment so it reads right and works.
    can u buy new equiptment for it and also get a tako for it.
    all help is greatly apreciated
    Jun 2005
    i take it you have a level 1 cluster? the dash with just fuel speedo and temp?
    i would suggest just buying a level 2 cluster for less than $50. this will give you a tacho and should fic your problems. having to thump the dash is a common problem and i think the only way to fix it is to do something to the voltage regulator inside the cluster.
    if you want to go an extra step, get a level 3 cluster from a calais
    1995 Manual HSV Clubsport
    1991 Supercharged VN Berlina
    ir8prim8 Guest
    ye it would be the lvl1 cluster (as u put it)
    where exactily do i go to get them form? can i buy them online? can i install them my self? is there any modifacations needed? if i can install it my self how hrd would u rate it form piss easy(1) to hard as all F*#@!(10) to do?
    Jun 2005
    what dash do you want to install, the level 2, or the level 3 calais dash? level 2 will just go straight in, but level 3 will require modifying the wiring, and im not sure how to do that on a VP. look around the wreckers for those clusters
    ir8prim8 Guest
    thanks again i will do that
    is it hard to ghet into the dash to install them or is it just a fiew pices here and there to get to it ?
  1. AUDIO EQUIPMENT - 4chan, 2 x 15" subs, 1000rms mono
    By petezor in forum Parts And Other Items For Sale
    Last Post: 04-01-2007, 12:16 PM
  2. Wwhat's the best setup using this equipment...?
    By grimavxs in forum Car Audio
    Last Post: 27-12-2006, 11:00 PM
  3. lower my car or buy audio equipment???
    By ruso in forum Car Audio
    Last Post: 24-05-2006, 04:48 PM
  4. Obligatory Office Equipment (OOE)
    By kowan in forum Jokes/Humour
    Last Post: 26-04-2006, 03:58 PM
  5. Replies: 2
    Last Post: 02-11-2005, 07:10 AM
