whenever i connect my battery up it sparks. my dad says it shorting out somewhere. but i cant find where it is if it is shorting out
so any help would be appreciated
Adam
that's normal. as you bring the terminals close together they'll arc. it should stop when you make proper contact tho.
yea it stops it after a while (put it on it sparks, take it off then put back on it sparks but not as much, take it off then put back on it doesnt do it at all)
i was just a bit worried.
thanks for the help
Adam
I had this bit of a problem, i just cleaned the connectors with some of that Steel wool stuff, And yeah didnt spark or make a sound ever again.
ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
thanks i will try that later and let u no how i goOriginally Posted by anton1o
Adam
interior/boot light is on
or maby radio/amp
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
i took the fuse out for the interior light cause the battery kept goin flat when i was working on the car.Originally Posted by burnz
i took the fuse out for the amp and it kept doin it and the cd player havent tryed(how do i check it?)
Adam
use an amp meter if low amperage 1or2 ampsOriginally Posted by _A_D_A_M_
this is probably clock or radio memory nothing to worry about
Powered By Garrett
yeah, there's always minor stuff drawing current. i wouldn't worry about it either.
how much are amp meters?Originally Posted by burnz
Adam
use a 100w light globe 12vOriginally Posted by _A_D_A_M_
if dimm no prob.
if bright find prob.
Powered By Garrett
and do i put that between the terminal on the battery and the lead?
Adam
exactly batt post and terminalOriginally Posted by _A_D_A_M_
Powered By Garrett
after you have cleaned them put vasilene on the terminals, it stops them rusting and it stops that white powder shit form on the terminal. My 2cents
KADE
!!"People seldom see the halting and painful steps by which the most insignificant success is achieved"!!
It's 9 O'clock on a Saturday, regular crowd shuffles in, theres an old man sitting next to me, making love to his tonic & gin
!"Why go for the light at the end of the tunnel when you can be the person to put that light up?"!!
