Results 1 to 6 of 6
Thread: how do i remove the harmnice balancer
    VN Berlina 3.8
    Apr 2005
    Default how do i remove the harmnice balancer
    i have a series 1 vn which dosent need a puller but how do i remove it i took of the belt and with a socket try and remoce the pulley but is spins with the socket so how do i stop it without doing any damage
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    there's a few tricks, some of which are quite dangerous....
    have you tried a breaker bar, with a real long pipe on the end of it, putting the car in like 5th or park in an auto, then pulling real damn hard on the pipe till it turns?
    I did mine in 5th with a sidchrome ratchet with a street sign post on the end of it, pulled on the post real hard, the bolt undid a little bit, ratchet mechanism broke, and i went flying back into another car then landed ass on the ground hehe!
    the other, silly and quite dangerous method is get breaker and pipe, rest it nice and tough against the ground, and turn the motor over with the starter... this didn't work for me because the bolt was too tight, but i don't recommend this method as it can be potentially dangerous.
    Reggie Guest
    hey there i'm a big fan of the breaker bar against the ground trick. it works, other then that , in a vn you have just enough room to fit a rattle gun.
    so long as you use a single hex socket and the breaker bar is against the ground, just give the key a tiny flick of the switch it will crack it most of the time. make sure no one stands near it (just in case) make sure it is on the passenger side of the engine bay. good luck
    HATER VP Guest
    Sometimes the bolts require heat. Other times ive had to remove the exhaust manifold, remove the starter motor, lock the ring gear and use a long breaker bar.
    VN Berlina 3.8
    Apr 2005
    cheers guys the breakerbar worked a charm. i couldnt fiure out however how to tighten it back up to its reckmend torque so i did as tight as i could by hand im scared its gonna fall of now
    HATER VP Guest
    Then swing past a mechanic and get them to check it for you. They SHOULDNT charge for that. I know i wouldnt
  1. harmonic balancer
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2009, 10:05 PM
  2. Remove Harmonic Balancer to change Crank Angle Sensor?
    By aklahr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-02-2007, 09:18 PM
  3. Harmonic Balancer...
    By sicko in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2006, 08:09 PM
  4. Harmonic balancer- a bit odd !!!
    By grindfiend in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2006, 09:11 PM
  5. harmonic balancer..
    By rattattack1313 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2005, 07:02 PM
