hey i lowered my car and put wheels on it 235s and got a wheel alignment but the things allover the road like carzy kinda side to side?? any ideas
i mite have a stuffed ball joint
cheers
did ya cut the springs?? or do it properlly. If its done prop did ya do it yourself. If ya did it yaself did you do it correctly. Do all the bolts up tight etc etc etc.. If you didnt do it take it back to where it was done. The people that did the wheel alignment should have told you if an anything was wrong.
yeah same struts outta my vn wags it drove fine
I would say that the tyres being 235 are the issue, i had a vp wagon that drive like crap with 235 on it, soon as i changed back to 215 it tracked spot on, try different tyre width if ya can.
Is it tramlining because of the wider wheels/tyres? You can find a car will follow the contours of the road much worse with wider tyres on it.
You could also be getting a bit of bump steer too on really bumpy roads. I don't really notice it on mine though.
What springs and shocks are you using?
Like a Set of 18" VY SS rims on a VL Calais. the front follows the road but the whole car still isn't badly balanced. Could he have a different issue?.
Originally Posted by Yoda
if it follows the road somthing is wrong check your strut tower rubbers for cracks they cause big issues if worn
im not admiring your car im looking in disgust
oh ok thanks for that ill check those rubbers and try skiny tyres
cheers![]()
