Results 1 to 12 of 12
Thread: Wait to go Backwards.
    VN s s2 and MY12 sv6 ute
    May 2005
    Darwin
    Default Wait to go Backwards.
    Just wondering if anyone else has the problem of waiting a few minutes after you select r on the auto tranmission for it to actually go backwards and if a fluid and filter changer will fix it. The problem only occurs on cold starts(well as cold as it gets in Darwin anyway). its been quite a while since the trannys been flushed.
    Full Spectrum's Avatar
    Full Spectrum is offline Customize your life.
    2000 Berlina V6.
    Dec 2003
    Melbourne's West.
    Blog Entries
    You wait min That doesn't sound to good.
    The old VB we had took 2-4 sec to engage reverse but never longer then that, And if in reverse it would shudder and slip if you used to much power.
    Quote Originally Posted by Yoda
    Do, or do not. There is no 'try'.
    <img src=http://forums.justcommodores.com.au/signaturepics/sigpic440_66.gif border=0 alt= />
    Gooblies Guest
    I had this problem too, and it took a while to go in 4th, I had to use 3rd to take off but when its warm its fine. I found that my oil level was Low. The runs up the side of the dipstick made it look high. I still got a new filter and oil to put in yet but its seems to be running fine now so I'll wait and see
    NORTI's Avatar
    NORTI is offline come get me
    VR Calais 5L, WM Statesman
    May 2004
    yep Id say fluid check. Check when warm with motor running for best result.
    D.
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    shift delay while the oil warms up is a telltale sign your seals have gone south. when they get old, they stiffen up, just like old people's joints (not the other type of stiffening..). as it warms up, the seals soften and start sealing, allowing sufficient pressure buildup to make the shift.
    making sure you've got enough oil and it's clean will help but if the seals are gone, it's days are numbered..
    Gooblies Guest
    jules's Avatar
    pimpin
    Dec 2003
    yes, as part of a transmission rebuild.
    that's why a fluid/filter change is the best place to start, it's a lot cheaper and easier. but if the seals are gone, the problem will likely return eventually, if the new fluid even helps at all.
    Jun 2006
    Try this before spending big $$$$$
    Go to transmission place and tell them you just want them to do a service which they should replace the filter in there and put new pan gasket and fresh oil and put back together its easy job dont pay no more than $80 as thats the average rate.
    Also your kickdown cable could be stuffed, where the throttle body is you can make adjustent its hard to explain but any mechanic can do it in 2 seconds so dont pay for it..
    Then go straight to Big W or Kmart and buy NULON transmission treatment and shake it up and then pour whole bottle in.
    Now drive the car around taking it easy stopping every 10 mins or so and putting car into every gear 1st,2nd,D N,R and do that a few times and see if it goes into gear quicker,If not then id say your gearbox is nearly dead.
    When driving does the car change gears ok?
    Hope this helps...
    VP WAGON V6
    Mar 2006
    jules's Avatar
    pimpin
    Dec 2003
    it's a TH700, there is no reverse solenoid i don't believe.
    in any case a delay won't be caused by a solenoid failure. that will be a go-no go proposition.
    May 2005
    Darwin
    It changes fine, done the adjustment on the kickdown cable. Done the nulon treatment.. Just think the filter may be blocked cause it only happens when starting first thing in the morning, the fluid isnt getting enough pressure to engage reverse. ill see if a new filter will do the trick. thanks for your thoughts.
    Jun 2006
    If engines cold and you select R first thing it might take longer to go into gear depending on age of transmission...
    going into D is easier as thats what transmissions used to ....
    Try this... in morning let engine warm up ... with foot on break go SLOWLY go into every gear from P to 1 then back to R.
    Do this from now on... and see if after filter service and nulon treatment if it gets better...
  1. 3 month wait
    By JD in forum Site Feedback / Site Problems
    Last Post: 19-11-2006, 12:57 PM
  2. Backwards
    By bazcom in forum Jokes/Humour
    Last Post: 02-09-2006, 09:53 PM
  3. would i be going backwards?
    By Wonderboy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-10-2005, 12:04 PM
  4. Backwards Fan?
    By paullmichelle in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2004, 10:30 AM
