Results 1 to 6 of 6
Thread: VN heater won't blow in right places
    VN calais 91
    Aug 2005
    Default VN heater won't blow in right places
    hi all
    i'm a noob and i know it
    i've got a 91 VN calais, auto with climate control and electronic controls
    my heater and A/C always blows to the feet, even when i switch it to face or windscreen
    i've compeletly removed the entire dash, and i've found the VAC pipes and heater unit
    i've checked all the servo pumps for the door flaps and theres no leaks from the pipes at this stage
    (i tested it by opening the flaps by hand, and put my finger over the tube opening which stops it from closing due to the vacumm)
    i've been told to check hoses from the throttle to the VAC ball, so i follow the only black pipe from the back of the throttle, goes to a T-section, one side goes to firewall, the other goes around to the airbox and into the wheel arch and then to nothing!
    i don't think i have a ball!
    but it's always worked before
    any ideas guys? thanks in advance!
    picts
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Hrmm so when you turn the Knob from Foot to Face.. Do you hear/see your vents flicking?
    Could be something as minor as the metal rod connected to the Switch being detatched.
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    HATER VP Guest
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The hose has to connect to something. I was told when fitting climate control to my 91 VN 2 months ago that if the 2 hoses that go throu the fire wall are connected around the wrong way it will only blow to your feet (read not work). My 91 VN is out at the moment so I cant check at this time but will have a sqwizz later tonight.
    PS there are no nobs to turn with climate control only buttons to push....
    VN calais 91
    Aug 2005
    hey all
    thanks for the help
    yehm, theres no ball, but before i took off the airbox, it was squashed under that, so i guess thats where the vaccumm was held
    however, i now have a new problem, so if you guys can help me
    http://forums.justcommodores.com.au/...358#post354358
    dans_vz's Avatar
    dans_vz is offline formerly vp_berlina
    05 VZ V6 Exec & 92 VP Calais SII V8 Manual
    Aug 2006
    Albury/Wodonga
    sorry guys for bringing up an old thread, but ive got the exact problem, but I dont understand how to fix it? can someone try to explain it a bit easier? lol im still new to cars
  1. How to blow 5k on a VN S1?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2007, 11:07 PM
  2. blow off valve
    By h0Ld3n`VN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-12-2006, 11:13 PM
  3. will this blow my sub
    By lieos in forum Car Audio
    Last Post: 27-08-2006, 03:29 PM
  4. so will a jaycar amp blow up when I...?
    By bezz in forum Car Audio
    Last Post: 22-05-2006, 01:13 PM
  5. Blow off valves.
    By vnberlwagon in forum General Discussion
    Last Post: 10-05-2006, 08:36 AM
