Hey peoples, my cars idle is a little bit lumpy, i know i will never be perfect.
So i had a bit of a looky see and everything looks pretty much as clean as it was after it was all degreased, except round the back of the motor. Behind the throttle body, below the level of the intake manifold there is like a flat at the back of the motor it has freshish looking oil there.
Just wanted to know if there would be anything else, other then the intake manifold gastket, that could be buggered to get oil there? I just cant see in behind there properly and $220 is a bit of dough to waste un-necessarily.
... Just went and had another look around and it also looks like my PCV valve has some oil leaking from around it could this cause any idle problems too?
Cheers,
Apoc.
i just did the same job on my v8. I had a bad idle too and after doing manifold gaskets it runs perfect. On the v8 the dizzy is up the back too which has a gasket that can leak but not sure about the v6
v6 runs dfi igniton, no dizzy, could be oil leaking out the bottom of the throttle body, through one of the small hoses.
V6 are known for leaking oil there it comes from the main oil seal or the valley gasket.
just replace the gasket, ALL v6's need replacing
its the first thing id do to a v6 when getting it...
