Results 1 to 5 of 5
Thread: Useing VPL3 CLUSTER IN VN DO I HAVE 2
    VN S2/ Original XRGT
    Jun 2006
    Default Useing VPL3 CLUSTER IN VN DO I HAVE 2
    Ok i have a VP berlina L3 cluster which i know works in my VN but what i'm wanting to know. Is the long strips down the bottom that have indecator,engine,headlights,spd,ect that light up will all the proper things light up in the right spots? or do i have to replace those long strips with the one's out of my VNL3 cluster.I'm just asking as i've heard people say theirs are'nt lighting up properly. Like engine lights up instead of SPD not exactly like that but you know what i mean.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    This is a pic of the layout of the dash. Unfortunatly i don't have a Level 1 or 2 one, but i'd assume there in the same positions, but if the option isn't avaliable, the globe isn't put in the dash.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    On the back of both clusters, should be the legend of each connector, write down the VN cluster on some paper and then comapre against the VP one, any differences will be which wires needs swapping.
    cheers
    Illegitimi Non Carborundum
    VR SS manual
    Apr 2006
    yeah u will need to change those strips more than likely as i used a 90 VN cluster into my VP and they were all different but on mine is wasnt as simple as just swaping them over as i went from lvl2 to lv3 and were in differnt spots so had to cut down and glue the strips into place
    or you could also do like FXST01 said change the wires over i just didint wanna much round too much with my loom
    Jun 2006
    It's all ok i've got it in all indecators and so on work!
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Useing a front VK windscreen rubber on a VL
    By kowan in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-10-2007, 11:38 PM
  3. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  4. Cluster
    By Phoenix21 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-04-2006, 05:51 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
