Hi, My vn wagon didnt come with a towbar or the pin-out plug for the lights. Once i get the towbar sorted, how do i go about tackling the wiring for the lights? Is there provision in the wiring for the taillights for a factory wiring loom i could maybe source from holden? If not im pretty competant in doing these things, where could i source an aftermarket plug and wiring for it? My old man has these little things that look like clips with a metal pin inside them, which can be used to tap into a wire which would make things easier for this type of thing.
your dads talkin about "scotch locks" i wouldnt recomend them. They dont make good contact at times causing problems in the wireing.
dont know about a factory loom, but they are pretty easy to make.
Just buy a plug and a meter of 5 or 7 core wire and install it yourself. 7 core if you want to have accessory power to a fridge or something, usually in a caravan. 5 core if you just need basic trailer wires(2 blinkers,brake,tail and earth). The earth will be white not black like in the car.
I tap into the wires near my tail lights and solder all my joins.
I dont know how wagon wireing goes but you should be able to find the main loom that goes to the back and join into it easily.
My VQ has a trailer plug thet plugs into the RHS tail light loom.Dont know if its factory but the plug is the same as the plug that joins the tail light loom to the car.
Hope this makes sense.
Adam.
Ive got a loom that plugs i n between the tail light connectors if you want it.
thanks hatervp, i might just take you up on that offer, Let me check the wiring i know they run up the RHS as i saw them when installing rear speakers, although i didnt notice any spare plugs i will check again to be sure. If it doesnt have anything there then dont worry about it mate, I will just go and buy a kit.Originally Posted by hatervp
cheers
I've got the same thing as Adam69 i picked it up from pick a part you can plug and unplug it straiate from the tail light loom.When you want to tow plug it in and have it coming out of the boot to the trailer when finmnished just sit it back in the boot or unplug it all togeather.I rather like it as i dont really like the idea of mounting the plug to the rear bumper or so.But if you dont know what color wire goes where if your buying a new plug it'll be on the back of the packet what each wire is for and where it go's.
Would that be the same for the wagon? The annoying thing is that i put a speaker where the access hole is to the wiring and theres extra bracing for it covering this:b: hopefully the opening is still big enough or I will have to drill out those rivets:b:Originally Posted by chopsy
Ok, I got my hands on a brand new genuine holden, towing wiring loom (the Flat 7 pin type) For the wagon owners out there it would be a great help if you you know where exactly it plugs into, i cant seem to locate where it goes to, there are some unused rubber gromets underneath but they dont seem to go anywhere.
Thanks in advance to anyone that can help me out.![]()
bump........
Mine runs from the top of the towbar and then up through the spare wheel well (the rubber grommet on the drivers side of the wheel well and then runs into the RHS tail light loom, not sure of how it's wired on and won't get a chance to take the trim off tonight but may get a chance to tomorrow...
Your a legend crazyspoon, I know theres an access hole on the RHS of the cargo bay area, I check mine tomorrow 2 but that would be great if you could as well. Mainly i just need to know if my car has the plug where the loom goes into, (which it should).
Thanks again
I checked mine today. You can see all the rear wiring behind the trim on the RHS of the cargo bay area. I looked on mine and there is no spare plug for the towing wiring harness UNLESS it plugs between another plug and acts like a splitter type thing.
So crazyspoon it would be great if you can check yours to see if it plugs between another plug or it hooks up to it own spare plug, so i will know if the genuine holden one I ordered will fit before i buy it.
Cheers.
Sorry about the delay, haven't ahd a chance to get the work done on the car until today
Picture of my taillight loom with the towing wiring being held, hopefully this helps you out
thanks mate,
Looks like your is a genuine holden one, Im pretty sure now that the harness im gettin will fit, it would be silly if it didnt.
I saw another picture of a genuine one and it plugs into the taillights loom and acts as a splitter type thing and provides another outlet for the plug it uses.
If worst comes to worst and doesnt fit for some unknown reason ill just get one from a wrecker of any random car and solder it on myself.
Thanks for your troubles.
