Results 1 to 15 of 15
Thread: hard to start when its warmed up
    VH SL/E 304 (injected)
    Jul 2005
    sydney
    Default hard to start when its warmed up
    i have had this problem since i bought the car 7 months ago, it starts first thing when its cold, it will still start up after being off for about half an hour but after an hour or so it takes a bit of cranking to start and then kinda splutters into life.
    any ideas?
    thanks
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by MontieVHSL/E
    any ideas?
    thanks
    Perhaps check the oxygen sensor(s). Are you getting any black smoke on startup when warm? Could be an indication of the engine running way too rich. Also check out the coolant temp sensor, it could be giving the wrong info to the ECU, also creating a rich mix.
    Reggie Guest
    yeah it sounds like a fuel prob. too rich to me also. ummm maybe leaking injectors,just a thought.when it starts does it blow black smoke?
    Reggie Guest
    try this, just to rule out leaking injectors. before you turn the car off take out the fuel pump relay. let the fuel system run dry and stall the engine. leave it for an hour, put the relay back in flick ignition on for five seconds do this a couple of times to get pressure back, then start it.
    Jul 2005
    sydney
    it doesnt blow smoke, i have looked for that. how would i check the coolant temp sensor?
    89 calais's Avatar
    89 calais is offline Munch,Munch V8'sfor lunch
    VN Calais
    Jun 2006
    Queensland
    Just a little trick you can try,take the car for a good drive and get it hot then make sure your back home when you turn it off.Try starting and if still the same problem pour water over your crank angle sensor.They have been known to cause this type of problem when they are old and overheat,then try starting the car again.If this is the problem the car will start easier,and if so replace your crank angle sensor,hope this helps!
    VP Executive R-spec
    Jan 2005
    vn wgn
    Apr 2004
    western subz melb
    tlndofa Guest
    IT IS YOUR CRANK SHARFT SENSOR,this does not start the car when warm if damaged but easy cold,tip water on it to start car first kick,2lt...is behind the harmonic balancer,bottom wheel of belt. (wire to it).ser 2 has plastic coating on it which tends to give protection but shorter life,also check trany oil ,may be low,an caused the problem...30$ for second hand sensor max..50$ labour max ...well after reading posts 89 calias is so correct.
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    As a couple of people have mentioned, if it starts when cold but is an absolute bastard when it's warm, the crank angle sensor is a common culprit and would be the first thing I'd check. As they have also stated, it's easy enough to diagnose that particular fault as well, just pour some water over it when it's decided not to start and if it starts afterwards then hey presto! If not then you've just narrowed down the possibilities with no expenditure.
    VP Executive R-spec
    Jan 2005
    Anyway has anyone else noticed it hasn't even been said what engine this is? I'm assuming injected 5 liter in the VH SLE but for all I know that has a carby 304 in it and hes talking about a V6 VN
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by greenfoam
    Woops, I'd assumed a v6 vn because it was in here, well picked up. If it's a carby 8 then thats a really weird problem and I have no idea what's wrong with it, usually the buggers are more difficult to start when cold. If it's an injected 8 then thats a really weird problem and I have no idea what's wrong with it, although common sense would seem to be pointing to the fuel side of things.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    Jul 2005
    sydney
    hey thanks for all the help guys! i havnt had time to do anything about yet. it is a vn 5ltr engine (injected). sorry i guess it was assumed, i should have mentioned that.
    VN COMMODORE V6
    Oct 2005
    Johnsonville
    I have the same problem but apparently in my case it has something to do with the gas computer. It seems to put both gas and petrol in at the same time. What can i do!!!!
  15. #15
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    Quote Originally Posted by tlndofa
    It's called a Crank Angle Sensor aka CAS...
    Get your facts right mate.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
  1. VP V6 Hard To Start - Help
    By oldfart in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-10-2010, 05:39 PM
  2. Hard to start
    By Ross S in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-03-2007, 04:51 PM
  3. hard to start
    By ads72 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-09-2005, 01:33 PM
  4. vn hard to start
    By stilly in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2005, 09:38 AM
  5. Hard to start
    By stheggie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-07-2004, 02:30 PM
