Results 1 to 6 of 6
Thread: VN Electric Arial keeps going down
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default VN Electric Arial keeps going down
    My arial keeps going down by itself. Hold the up button until a light click sound. Then down she goes at some time.:b:
    Replaced the control unit with the other car - no change.
    Put the arial in the other car. Other car has problem.
    Anyone had this problem before?
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    If its not the aerial module, then its an aftermarket aerial.
    Aeropro aerials etc. often do this and from Brand new. I had my genuine aerial replaced cause the motor was gone, and I have the same problem.
    If it bothers you, just skip the module. Wire the aerial straight to the cd player, then when you listen to the radio, it will go up...when you listen to cd's or turn the radio off, the aerial will go down.
    88GreenVN's Avatar
    Jun 2006
    vl berlina,vl nothing,vt v8 ex police
    Aug 2005
    perth WA
    Ive got the same prob,best way is when the aerial gets to the top pull out the fuse
    HATER VP Guest
    Did this happen after putting in a CD Player? What happens if you hold the up button, does it stay up. If it does slip in a 5c in there to keep it up.
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by bencom
    lol ummm... Isnt that a little overboard? Having to replace the fuse all the time? Much easier to just remove the aerial module and connect the wires straight to the aerial so it goes up when the radio is on, down when the radio is off...
  1. Cruise control/electric arial
    By n1tr0us in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2006, 10:50 PM
  2. Arial Replacement
    By jabbavx in forum Car Audio
    Last Post: 24-02-2006, 02:39 PM
  3. VQ arial
    By yotaman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2005, 04:29 PM
  4. Fitting Factory Electric arial + VN
    By VN_WA in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-06-2005, 11:44 AM
  5. Replacing a standard arial with an electric one
    By pete's_VT_Wagon in forum Car Audio
    Last Post: 15-05-2005, 11:30 PM
