Results 1 to 9 of 9
Thread: Electric window arms :(
    NVE_069's Avatar
    NVE_069 is offline Vx Calais / Ve Berlina
    Vx Calais LS1 / Ve Berlina V6
    Mar 2005
    Default Electric window arms :(
    Who has had the elec window arms twist on them. i have which i replaced it yesterday an that oen too did the same thing now im thinkn on just going wind ups in thr front im over elec lol
    cheers
    VN BT1 - 5.0
    Apr 2005
    Perth, W.A
    does your window get jammed at the front of the window then tilt and totally screw up? there is a seal in the front runner that gets crossed up alot, happend when i had my winders in and also to my brother when he had his VR, i just completely took that seal out, works a treat now, little bit of a noisy scraping sound though.
    this could be your problem coz if you replaced it and it did the same thing, it's either installed wrong or your seal is busted. hope this helps
    Rolling in a 5.0
    NVE_069's Avatar
    Mar 2005
    yeh iot tilts when when winding down an up, at 1st it goes down alrite untill about half way than goes down reaalllyyyyy slow an than makes a loud crack noise so im not game to wind it all the way but now when i do wind it down it tilts
    cheerz
    VP ute
    Mar 2006
    Look at it a bit closer.
    There are some white plastic bits that fit inside those slider rails inside the door.
    They wear easily and cause the window to tilt a bit as well when they jamb up a bit.
    You can pick these up from Holden very cheaply.
    Also the metal in the outside bottom corner of the door where that bolt is to hold the channel, is very thin and when things are not flowing smooth this flexes alot to make it all worse.
    Take the opertunity to replace those plastic slide things, then inspect the channel seal, then ensure the channels are adjusted properly.
    NVE_069's Avatar
    Mar 2005
    thanks for that i will do when i get some time lol. busy taken the leather out atm
    cheers
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    I always replace both bailey channels as a matter of course when replacing a window reg on these. theyre about $15 each
    Cheers Rob
    NVE_069's Avatar
    Mar 2005
    VP ute
    Mar 2006
    NVE_069's Avatar
    Mar 2005
    yeh i was abit worried than lol as thay charge an arm an a leg for some things
  1. electric window problem
    By redcedar in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-03-2011, 11:13 PM
  2. Painting window wiper arms
    By dawg in forum General
    Last Post: 06-12-2006, 05:42 PM
  3. VY Electric window switch into VL !!!!
    By Rogue-VL in forum Electrical Wiring / Questions
    Last Post: 11-07-2006, 06:51 AM
  4. VK Electric window switches
    By hold.on in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-02-2006, 12:29 AM
  5. WTB - electric window parts
    By stocky in forum Swap / Wanted to Buy / Trade
    Last Post: 11-01-2006, 12:25 PM
