Results 1 to 10 of 10
Thread: mounting the alternator elsewhere
    VN Commodore
    Feb 2006
    Default mounting the alternator elsewhere
    this is going to sound stupid, but i am going to ask anyway. has anyone ever mounted the alternator in a different spot. the reason i ask is because i came up with a stupid idea that may work if i could get the alternator out of the road. i want to get an old motor to pull the manifold off the see if i can get it to work. I thought if ya pulled the inlet manifold off and turned it around the other way. so there throttle body and thermostat was facing the front. does anyone reckon this is possible.
    HATER VP Guest
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    i actually thought of this as well, water galleries look like like they will line up, as they are on opposit sides, be good to find out though, as for the alternator , i wouldnt have much idea, other than you may have to change some pulleys and put adjusters and crap, good luck anyway
    VN Commodore
    Feb 2006
    unless the v6's have a left and right head i can't see why the water gallery's wouldn't line up..
    HATER VP Guest
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    yes, should bolt up the other way.
    id suggest using a s2 manifold, then the thermostat will be at the back, but the hose wont be in the way like it would with s1 turned 180deg.
    heres a pic of my alternator bracket. as im doing a similar project. and no, i wont say what. this is all im posting up til its done.
    Attached Thumbnails Attached Thumbnails mounting the alternator elsewhere-pict0060.jpg   mounting the alternator elsewhere-pict0061.jpg
    HATER VP Guest
    Thinking about it, it maybe possible. Keeping in mind there are sensors on the front. The T/B elbow could possibly be rotated and have a V8 style airbox. I wouldnt be trying it tho. quite abit of dicking around for no reason.
    VN Commodore
    Feb 2006
    all wires and hoses can be alterered. that isn't the worry. if it will bolt stright up, which i think it would. then getting the alternator out of the road..
    i want to use the series 1 inlet, as i want the thermostat at the front. i want the throttle body at the front too. so my turbo will be sitting right next to the throttle body..
    VP ute
    Mar 2006
    check out the american sites for this mod.
    Also the intake plenum can be turned round with some mods but they will be teadious. There was an American on another forum who has done this as well as combining the better bottom end from our VN VPs and the better heads and intake from the Ecotec.
    The alternator can be fitted under the rear of the car and run off the drive shaft.
    VN Commodore
    Feb 2006
    i don't want to go that far. mounting it on the driveshaft.. too much effort for the little result i would be getting.. i don't know how good that would be either.. wouldn't be spinning with the revs of the motor then..
  1. Replies: 0
    Last Post: 07-11-2007, 08:25 PM
  2. mounting h/u (vt)
    By SweetWagon in forum Car Audio
    Last Post: 18-10-2007, 01:52 AM
  3. mounting hu in vx2
    By ilovemyvx in forum Car Audio
    Last Post: 23-12-2005, 05:37 PM
  4. Amp Mounting!
    By raZel in forum Car Audio
    Last Post: 22-09-2005, 07:29 PM
  5. Amp Mounting
    By Spanner in forum Car Audio
    Last Post: 20-11-2004, 03:46 PM
