Results 1 to 6 of 6
Thread: Whats involved??
    1972 mini clubman
    Jul 2005
    Default Whats involved??
    whats involved with putting a starter motor in a vn berlina wagon? 3 bolts and a positive and a negative isnt it? any help would be much apreciated
    cheers
    HATER VP Guest
    1972 mini clubman
    Jul 2005
    HATER VP Guest
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Apparently removing the exhaust manifold on that side can also make it a lot easier to get at if you're having trouble with access.
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by hothead115
    cheers
    hey man i did this recently, not really hard
    1st step
    start by disconnecting the battery, remove the spark plugs but write down a diagram of where they were so you dont get struck apon re-assembly, jack the car up and put it on stands, this is a MUST because of what u have to do... use a socket set, dont try using a spanner you wont get the torque you require, borrow one if u have to,
    2nd step
    jack the car up and put it on stands on the jacking points on both side of the engine, now unbolt the headers at the head, there should be 6 bolts, without a socket wrench kit this will be VERY hard, then get under the car and soak the bolts with wd40 that join the headers to the exhust, let it sit for 5-10 mins then undo the bolts
    3rd step unbolt the starter motor (from under the car there is 2 verticle bolts, get the LONGEST handle socket wrech u can get or this is NEAR inpossible (trust me had to buy one when i did it)
    from there there is one more bolt on the block, horizontol at the other end of the starter motor..
    4th step Unwire the starter motor, this is pretty self explainatary, copy how the old one was wired up
    5th step you can either shield ALL spark cables and crank it over, WARNING, if you dont have leads/the ends shielded you can do some serious damage to things, make sure NONE are touching the chassis, when i did mine i left the leads off and there was arching between the coils on the coil pack, must have been around 30,000V (not much current)
    6th step With your new starter motor working fine, bolt the headers back on, put the spark leads back in, and reconnect the battery
    PLEASE make sure the bat is always disconnected before you work on the car, its easy to forget after testing if it cranks.... i know it dosnt have one at the moment but yeah
    hope this helps
  1. Whats involved in changing heads
    By Rosco666 in forum Straight 6 Development And Modification
    Last Post: 22-09-2006, 12:42 PM
  2. whats involved in getting cams licence?
    By calais_304 in forum Motorsport
    Last Post: 31-07-2006, 11:00 AM
  3. Whats involved in putting a t5 on a 253?
    By Mattie77 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-10-2005, 09:37 PM
  4. whats involved in changing springs
    By crainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2005, 11:15 AM
