Results 1 to 7 of 7
Thread: fuel pump
    1990 30th anniversary ea ford wagon
    Jul 2006
    hallam
    Default fuel pump
    fuel pump has gone and was wondering if anyone knew where i can locate it?
    its a 88/89 6 cyl. vn.
    does anyone happen to know the price of a new pump also and is it an easy job?
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Im not entirely sure on the price... but depending on your knowledge its not an easy job. You have to de-pressurise the fuel tank and empty the fuel tank and you will find the fuel pump behind the fuel guage sender unit..
    This recent thread tells you how to remove it from the fuel tank unit:
    fuel pump removal
    1991_Vn2nV's Avatar
    Mar 2006
    Heres the information I gave in the thread anyway... But before you get to this stage you must depressurise the fuel system and disconnect the negative battery terminal... Plus the rear of the vehicle must be raised and supported and then you have to empty the fuel tank with a hand pump or something.
    Quote Originally Posted by 1991_Vn2nV
    Ok well Ya gotta disconnect the wiring connectors from the fuel guage sender unit and then loosen the hose clamp and remove the fuel hose hose from the fuel guage sender unit as well.
    Then remove the retaining screws from the fuel guage sender unit and manouvre the sender unit and the fuel pump assembly from the fuel tank.
    Disconnect the wiring from the fuel pump and remove the strainer from the fuel pump inlet.
    Then ya just need to slide the pulsator along the pick-up tube until it is clear of the fuel pump outlet...then manouvre the fuel pump from the mounting bracket.
    Jul 2006
    hallam
    cheers for the info. it'll give me sumthin to do on the w/end.
    but wont impress the misses much!
    2greedy is offline VP Calais (SSV)
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    as far as price goes m8 i bought 1 through autopro the other day and it cost me $115 but they range between 100 and 120
    vp manual wagon Guest
    Hahahaha hope you didn't fill up before the barsted conked out on you! I hated the last time that happened......Mine didn't on the west gate, and i had to kick the rear end like a football just to get it to start and get off that bridge in peak hour... I F****** hate fuel pumps...grrr
    Jul 2006
    hallam
    $25 worth of fuel which took it to a 1/4.
    luckily i run gas too, but its sluggy as **** on gas!
    going to get someone to do it for me. with labour im looking at about $190.
  1. fuel pump?
    By bendez in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2007, 09:35 PM
  2. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  3. VN Fuel Pump ?
    By snowcatz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2006, 10:07 AM
  4. VN Fuel Pump ?
    Last Post: 08-02-2006, 09:58 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
