Results 1 to 13 of 13
Thread: VN throwing fan belt
    vn commodore
    Jul 2006
    Rockingham WA
    Default VN throwing fan belt
    hi all, my vn keeps throwing my fan belt , the tensioner is only at a quarter any ideas
    Thanks
    Rhiann
    HATER VP Guest
    Any pully starting to seize? Or any pull mainly the Harmonic Balancer moving?
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    check tension tension, may have given way
    ummmm yeah check harmonic balancer
    vn commodore
    Jul 2006
    Rockingham WA
    Ive had the balancer checked and seems to be fine, the original belt was old and i had it fixed by a mechanic, since then its thrown it 4 times, is there any chance it might be a later model belt that could be a little longer, ive rang super cheap and they said thats not possible
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    where does the tensioner gauge line up to? Look for the arrow/triangle on the swingarm
    Illegitimi Non Carborundum
    vn commodore
    Jul 2006
    Rockingham WA
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The tensioner may look ok but what about under load?
    Is the water pump OK?
    missus (in more ways than one)
    Sep 2005
    check all pulys and play close attension to the air con pump. the bearings in these fail and they become a bit wobbly, which under a few thousand revs a minute could throw it off the water pump, leading to the belt taking a holiday. which is quite dangerous cause then you got no (power) steering and no water.
    but if you ant a quick fix go to repco and ask for a belt for a vn without air con, the shorter one.
    vn commodore
    Jul 2006
    Rockingham WA
    yep, all the pulleys are fine, but just to make sure, dad replaced the tensioner pulley, the water pump, power steering and air cond seem ok even under load, do you think that later models may have a bigger belt????
    Toyota Supra Turbo
    Dec 2005
    SE Suburbs, Victoria
    it will be the harmonic balancer, mine balancer looked fine as well, and it kept throwing the belt, expect to pay about $300.
    Adam
    1990 VN S1 V6 Calais (SOLD!)
    1996 Toyota Supra Turbo
    HATER VP Guest
    Like I said before id be saying balancer but check the tensioner as well. See how much movement it has when you start it up. The tensioner will loosen when you start it so there not much load on the engine. Also with a 18mm spanner see how hard it is to loosen off the tensioner.
    vn commodore
    Jul 2006
    Rockingham WA
    just noticed another thing, when the motors cold the tensioner basically doesnt move, but when its warm it seems to run a bit rough and the tensioner jumps up and down a bit. the tensioner has been replaced with a new one
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    maybe a dodgy tension??? it does happen
  1. Serpentine belt (Acc Belt)
    By AttaBoy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2007, 12:12 PM
  2. Anyone throwing out a motor?
    By shaggerz in forum The Pub
    Last Post: 20-09-2006, 12:41 PM
  3. Throttle body throwing
    By VNV6VENGEANCE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-08-2006, 11:03 AM
  4. Replies: 37
    Last Post: 13-01-2006, 01:25 PM
  5. How goes the fan belt?
    By Stumped in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-08-2005, 10:48 AM
