Results 1 to 9 of 9
Thread: Help fitting towbar
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    Default Help fitting towbar
    Hi, I recently got my hands on a towbar for my vn wagon. I simply cant put my head around how it bolts up underneath. I can see the mounting holes either side under the car, but when looking at the towbar you can see the bolts heads seat on the top and a nut at the bottom? hows does that affix to the car?
    I included a picture so you can get a better idea, If anybody has done this before, please enlighten me. Thanks
    HATER VP Guest
    Ive removed a few, but never put one in. It dosent look like a fun job.
    Years ago when I was working at a Toyota dealership they used to fit them following a set of instructions. Every model was different and had provisions for the genuine kit. I didnt like to get involved in that stuff
    HATER VP Guest
    What you need is someone with same car and tow bar set up to messure where the holes are.
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by HATER VP
    It already has the holes there in the frame rails on the car (its a factory towbar), The bolts cant simply screw into them can they? I cant think of any other way, its not like i can get inside the frame rails to do the nut up or put the bolt through as seen in the photo, its got a bolt with a nut, one way or another i wont be able to access whatever end of the bolt is inside the frame rail to tighten it up
    Its got me stumped
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    2 person job, unless you use a jack to hold the towbar in place while you put the bolts in. The nuts are usually welded to the towbar so that the nut wont fall off if it manages to come undone(i have never heard of them coming undone)
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Quote Originally Posted by maginoodle
    The holes for the bolts are on the chassis rails, how do I "put the bolts in" when I have no access from the other side of the hole?
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    After some brainstorming, If i take the rear bumper off, will the open ends of the chassis rails be visible? Then I could have access to the inside of the mounting holes
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    SweetWagon's Avatar
    Jan 2006
    Springwood NSW
    Just letting ya know, the towbar went on without any trouble, it took about 2 hours, Had to drill some holes in the top cargo bay area on each side above the chassis rails for the bolt holes but all went well
  1. VN Wagon towbar fitting
    By thespirit in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-06-2010, 05:24 AM
  2. VN Towbar
    By Anthraxnz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-09-2007, 09:12 AM
  3. VX towbar, will a ute towbar fit a wagon???
    By Phrog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-01-2006, 03:31 PM
  4. towbar vx to fit wh
    By hsvgtsr1 in forum General
    Last Post: 20-07-2005, 04:36 AM
  5. VP Towbar
    By Ziggie in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-01-2005, 02:10 PM
