Results 1 to 8 of 8
Thread: vp wont start
    VP Calais
    Jul 2005
    Default vp wont start
    i was bout to go out tonight but ran out of fuel... when i tried to start the car it started... moved a bit then stoped. ...so pop down to the servo and filled two cans up. put it in the car but it still wont start its not even trunin ova its completly dead. it started then went dead befor i put some fuel in but when i put some in nothing now no ignition nothing... can someone help me..
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    Check the fuse for the pump under the bonnet.If you run them out of petrol it is pretty common for the fuel pump to die.I might have only got hot and it blew the fuse.I got a very noisy pump coz it was low on fuel,put in fuel and it was quiet for bout 10 min then the car died.Fuse gone.lucky i run gas so i just disconnected one of my pumps and all is well(but no petrol).
    Try the fuse first and hope the pump is OK.
    Good luck.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    That could be it, or, if you tried turning her over too many times, you may have flattened the battery.
    The 1972 HQ Kingswood
    vp manual wagon Guest
    You can remove a hose and see if the fuel pump is still working can't you? Sounds like a flat battery as well....If your car is also on a slope going left, right or on a decline, it also may be hard for the pump to suck the fuel in at times if theres only a little bit of fuel in....how big are the cans?
    Oh thats assuming the pumps still working.....Never trust a vn-vs fuel pump....or fuel gauge..or anything fuel related lol!
    Morton's Avatar
    May 2006
    lol, too right you are. My fuel gauge goes a full 10mm below the empty line before she starts spluttering ^^
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    Chain Reaction Champion!
    Feb 2006
    North Tassie
    Quote Originally Posted by vp manual wagon
    You can remove the fuel line from somewhere (I'm not too sure where) near the inlet manifold, and just turn the key far enough so the fuel pump (should) start to work. If all is well, the fuel should come out in a fairly steady stream. If it just dribbles out the end of the fuel line, then there's something wrong.
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    a mass/axe murderer by night
    :: hakhawk :: says:
    and a rabbit sometimes
    I'm only nice to one person per day. Today is not your day....
    Tomorrow doesn't look good either.
    God must love stupid people, He made so many.
    VT Clubby
    Oct 2004
    Listen for a click noise coming from the fuel pump relay if no click then no power.
  1. VX wont start
    By _VX_S_ in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-02-2007, 02:50 PM
  2. VS V8 wont start
    By rus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-07-2006, 11:39 PM
  3. It just wont start...
    By VL86Berlina in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-02-2006, 07:08 PM
  4. why wont it start???
    By only-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-02-2006, 03:15 PM
  5. Help wont start
    By kasey375 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2005, 05:16 AM
