Results 1 to 5 of 5
Thread: vn commodore near stalling
    riker Guest
    Default vn commodore near stalling
    i have a V6 VN commodore which feels like it going to stall. It loses power then kicks back in, on the odd time it will completely stall when its low on fuel. I am only getting between 250 and 350 k's out of a tank around town even less when on the open road. I have had a major service done, filters changed, injector cleaner but in, gearbox service, fuel system check. Nothing seems to work.
    There are are no modifications done to it as far as i am aware. I don't have lpg installed.
    can anyone help me with any suggestions on what might be causing this to happen or if anyone else has had the same sort of promblem and knows how to fix it, could you please let me know. please email me.
    email: andrewgoatley@hotmail.com
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    check for vaccum leaks and if you still have no joy try a map sensor that worked for me ive also heard of crank angle sensors causing similar issues
    mine is manual and it actually would stall between gear changes but only when it was cold
    im not admiring your car im looking in disgust
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Replace Oxy Sensor. Throttle Body Sensor. That will help fuel economy.
    Any codes from the ECU?
    Jun 2006
    Check your fuel lines for leaks whilst engines running, also while car is running go to back of car and listen if your fuel pump is making loud noises, another thing it could be is fuel pressure regulator...
    SOunds like cars starving for fuel so fuel pump,fuel pressure regulator.
    or you have blocked fuel line or bad fuel hose...
    check the fuel line hoses near throttle body as this is where mine leaked from until i fixed it..
    vpcalaisv8 Guest
    I have a V8 VP Calais with the same problem, i took it back to holden several times and the only thing that seemed to have any effect was cleaning out the throttle body. But a month later its started to do it again, especially when its low on fuel (which could just be a coincidence) It could still be a fuel pump problem, but thats quite annoying to fix, let me know if u get it sorted i'd be keen to know!
    reading a few other posts, it looks like the throttle body sensor could be the problem, apparently quite inexpensive to fix, might give i a crack
  1. 98 Vt Commodore (stalling)
    By broomie21 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 08-11-2009, 11:00 PM
  2. VT2 Commodore Intermittant stalling
    By VTsuper6 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-04-2009, 01:28 AM
  3. VX Commodore stalling whilst driving!!!
    By chipper_222 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-03-2006, 12:47 PM
  4. 98 Vt Commodore (stalling) Part 2 !!
    Last Post: 31-07-2005, 04:44 PM
  5. Vs Commodore-Stalling+Starting Difficulties
    By iamdvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2005, 09:04 PM
