Results 1 to 6 of 6
Thread: harmonic balancer help needed asap.
    VN v6 s2 Berlina 5spd
    Mar 2006
    Default harmonic balancer help needed asap.
    well, earlier this year before i got my series 2 in the harmonic balancer got chewed to bits and had a massive delay and a terrible knock.
    guess what, 3 months later and i think its happened to the series 2 motor.
    i had a massive delay and backfiring only in 3rd 4th and 5th and i was wondering if this could be the harmonic balancer?
    it also has a massive delay and rough running in neutral,
    almost like its out of time.
    how can i check its the balancer and not something internal?
    thanks guys.
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    What does this 'Massive Delay' mean?
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    Mar 2006
    when i had the series 1 auto and the balancer went out
    i would put my foot down and it would shake and nearly backfire till it got to
    about 2000rpm than take off
    the manual isnt as bad but it has a delay since today
    i try reving it freely in neatrul and it doesnt rev up instantly to rev limit it takes longer
    i mainly want to know if this is the balancer and not internal.
    i cannot see any visible damage too the balancer from a week ago,
    it already has afew cracks but i cant see past to the rubber to the metal so i cant tell,
    HATER VP Guest
    Mar 2006
    not yet but it only happens when i put a fair bit of load on it, like in 3rd and 4th trying to put your foot any more then 1/4 on the pedal it splutters n shakes.
    seems not so bad in 1st and 2nd but i cant flatten it at all till bout 3000rpm.
    plus theres a major loss of power down low and mid
    cheers for the reply
    Reggie Guest
    i would say that your harmonic balancer prob on the series one motor was very rare? i would be looking for a missfire problem. such as spark or fuel.
    can you rev it all the way if you put your foot down slowly? if so i would try another coil pack and module off another car. maybe plugs and leads check them, definately sounds like a load problem. map sensor? throttle position sensor? just for some ideas
  1. harmonic balancer
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-08-2006, 08:37 PM
  2. Harmonic Balancer
    By rredbeak in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-08-2006, 10:30 PM
  3. probably a harmonic balancer
    By mickah in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2005, 04:38 PM
  4. harmonic balancer..
    By rattattack1313 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2005, 07:02 PM
  5. Harmonic Balancer
    By warrick in forum General
    Last Post: 09-07-2004, 11:23 PM
