Results 1 to 7 of 7
Thread: bubbling radiator
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    Default bubbling radiator
    hey guys. i dont no if this is normal but my car has always done. for some reason i quite often here my radiator bottle thing bubbling and making odd noises. i think its often worse wen im a little low on water.
    is this normal or should i get my radiator checked. i have a new/ second hand radiator as my old one split and i only just flushed and cleaned out my water system
    check my ride
    http://forums.justcommodores.com.au/...ad.php?t=16665
    and feel free to comment
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    I had this happen in my VL..Are you just running water in your radiator or what? You cant just use water or cheap coolant in VN's.
    I ended up having my radiator replaced. As it turned out there was a blockage in your radiator. Seeing as you have a series 1 you cant check the coolant level under the radiator cap as you have no radiator cap... Take it to a radiator place perhaps and get it checked and if there a blockage they will clear it or replace the radiator.
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    ok well i no my radiator isnt blocked as my old one did this too, and as for clooant like all added oils and stuff like that i buy the most expensive i can aslong as its effective. i use that longlife stuff just cause its stronger. and i ran cleaner in it about 2 weeks ago, the water unfortanelty was a little brown
    check my ride
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    Could be a blown head gasket. Had a vh once that always had bubbles coming from the radiator, both the tanks blew off the radiator from the extra pressure getting in the cooling system from the combustion chambers. had to change the rad as well as the head gasket and solved the problem.
    1991_Vn2nV's Avatar
    Mar 2006
    VN-88's Avatar
    vn v6 s1 manual
    Aug 2005
    1991_Vn2nV's Avatar
    Mar 2006
    *shrugs* lol if it worries you take it to a radiator joint to have it all checked... might be a good idea anyway. But I dont think its anything to majorly worry about
  1. bubbling/water sound coming from dash
    By tep_aus in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-06-2009, 12:37 PM
  2. Bubbling Paint
    By Grennan in forum General
    Last Post: 30-04-2007, 10:49 PM
  3. fuel tank bubbling
    By vt com in forum VL Holden Commodore (1986 - 1988)
    Last Post: 31-12-2006, 09:55 AM
  4. bubbling problem
    By sulley in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-12-2005, 10:47 PM
  5. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
