what revs does everyones VN V6s run at 60 km/h?
i think my auto might be stuffed. mine runs at about 1100 in top gear.
is this normal?
also, mine is changing up at about 1700-2000
is that normal?
Sounds normal.
Myns about the same.
If your tranny was stuffed you would know about itUnless it's changing at that rpm flat out?.
I can have my car shift into top gear by about 55kp/h cruising. It can shift around 1400-1600rpm at lowest rpm every gear, It sits about 1100 @ 60kp/h on the freeway it sits about 1700-1800rpm @ 100kp/h. and my tranny is a rebuild.
Originally Posted by Yoda
mines full rebuild stage 2 shift 2500 hi-stall sits on 100km at 2100 60km at 1500Originally Posted by SlickHolden
60kph is about redline, in first (manual) LOL
In 4th though my tacho (it's a bit sticky) sits somewhere between 1200 and 1800. But as I said, the tacho sticks a bit, so it's hard to tell exactly.
Gravity is proof that nature keeps getting us down.
Must be the Stall and shift kit?. Myn s just stocky.Originally Posted by stockvp
