Results 1 to 8 of 8
Thread: vn wagon handbrake
    vn exc/vtss
    Oct 2005
    Default vn wagon handbrake
    Hi all.I have a vn wagon with a bad handbrake.I have adjusted the cable but it won't hold the car.It has a disc brake rear end.Just wondering if the rear brakes have separate pads or shoes for the handbrake as found in some cars.If so has anyone ever changed them.Any help would be greatly appreciated.
    VN S1
    Sep 2005
    Whilst replacing the pads on my car a couple of weekends ago I adjusted my handbrake as well. The handbrake is a separate shoes and drum arrangement incorporated into the disc. It's quite easy to adjust. All you need do is remove the calliper, pull off the disc, you'll see a notched wheel for adjusting the shoes - adjust each shoe the same. You should only need to move each around 5-8 notches. Replace the disc/drum - You'll know if you have gone to far with the adjustment as the drum will not slide on easily. Check that there is no drag. Attach calliper. You can also adjust the Handbrake cable a little from under the car.
    VP WAGON V6
    Mar 2006
    the shoes are liike EXPENSIVE... something like 150 or something.
    - OWA650 -
    "Blown Vr wagon, 275hp at the wheels.. Much more to come in the near future!"
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by commy92
    Can't imagine why you'd ever need to replace them though, it's a handbrake, it doesn't do an awful lot of work unless some retard is trying to pull handbrake turns, the shoes should last practically forever.
    Mongoose has explained quite well what needs to be done, once the brake disc is off it's easy enough to work out how to move the shoes outwards. Just be careful that you don't move them out too far, ya don't want the shoes dragging and creating a lot of heat. Took me ages to get mine just right, haven't had to go back and redo it though so I'm fairly happy.
    VN S1
    Sep 2005
    No they aren't. I pretty sure you can get a set from Repco for around $30.
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    just pulled out previous service invoice.. $35.70.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    also when lookin at invoice i saw "Brake Caliper Paste".. what is that used for? (sorry if hi-jacking but not worth starting new thread just for that )
    My (ex)Ride
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    bump... come on this cant be a hard question
    My (ex)Ride
  1. handbrake
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-11-2006, 01:24 PM
  2. fix my handbrake help
    By medz84 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-03-2006, 10:22 AM
  3. Handbrake
    By lazza93 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-12-2005, 11:33 PM
  4. VS Handbrake
    By rallyraid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-09-2005, 10:08 PM
  5. VS Handbrake
    By KILLERVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2005, 07:16 PM
