Results 1 to 9 of 9
Thread: tacho
    38VNIT's Avatar
    38VNIT is offline Azerium
    nothing
    Jul 2006
    Inverell
    Default tacho
    Hi all, went and wired in a tacho today, but there is a small prob, it idles good, but then when u recv it it freezes at 1500, so i took it for a drive thinking it may not work in park, but as oon as u give it acceleration it drops to zero, now iv tested with 2 tacho's and same prob, but all the wiring is fine, i was thinking its loosing signal by the time it reached the tacho, could this be it...
    38VNIT's Avatar
    nothing
    Jul 2006
    Inverell
    VN v6 s2 Berlina 5spd
    Mar 2006
    i had the same problem on my tacho, (which i pulled out cause its over excessive for a stock six but least its a manual)
    try checking that it getting a good earth
    try double checking all the joins.
    mine worked after i earthed it better.
    38VNIT's Avatar
    nothing
    Jul 2006
    Inverell
    does anyone know if the execs have a tacho wire behind the dash, or do u have to use the one following up the right hand side of the motor (proper tacho cord)
    Mar 2006
    yeah they do.
    brown wire with red stripe.
    pop off the cover under the steering wheel and find the loom going upto the dash, unwrap it and splice it in to that wire.
    thats on a exec vn
    be shore to keep it connected so it still goes to the dash or ecu.
    38VNIT's Avatar
    nothing
    Jul 2006
    Inverell
    Default hey
    well we got the tacho working, was a bad earth but my mate vrought a tacho today and wired it up, didnt work, then we tried it on my car and didnt work (has a working tacho) so we went and swapped it for the same one but a new 1, neway same prob, on both cars, has a back light and is wored fine but the version tacho just wont pic up ne help...
    Mar 2006
    38VNIT's Avatar
    nothing
    Jul 2006
    Inverell
    yeah but we wired his tacho into my car and it worked but when we hook his into his it doesnt work, and when we hook mine into his it works, its just the 1 tacho, and we have swapped it for a new 1...
    38VNIT's Avatar
    nothing
    Jul 2006
    Inverell
    lol i will return the cheap one cause i just one this on ebay
    http://cgi.ebay.com.au/ws/eBayISAPI....MEWN%3AIT&rd=1
  1. VN Tacho-Less Dash To Tacho
    By Evman in forum General Discussion
    Last Post: 01-03-2008, 08:32 PM
  2. Dash with tacho fit into dash w/out tacho and work????
    By Jamie_87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 09:21 PM
  3. tacho
    By blue vn in forum Electrical Wiring / Questions
    Last Post: 19-11-2007, 01:08 PM
  4. tacho help
    By 38VNIT in forum Electrical Wiring / Questions
    Last Post: 29-07-2006, 07:55 PM
