Results 1 to 4 of 4
Thread: level 3 cluster led replacement
    vp vactioner wagon
    Mar 2006
    Default level 3 cluster led replacement
    hey guys
    ive got a level 3 cluster out of a vq stato
    how do i replace the led's in the digital screens at the bottom??
    cheers
    HDT_aero is offline resident bush mechanic
    manual VN aero
    May 2005
    SA
    they are globes and if you pull the cluster apart you will see them in the rear pcb they cost about $60 from holden each and there is three or four of them but you cant get the globes anywhere else
    be carefull taking it apart and putting it back together as the plasic gets very brittle after 15+ years
    im not admiring your car im looking in disgust
    vp vactioner wagon
    Mar 2006
    manual VN aero
    May 2005
    SA
    if you can be stuffed you can replace them with leds by soldering them with appropriate resistors straight onto the pcb
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. replacing level 2 cluster with level 3
    By Matt_vp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-01-2010, 09:30 PM
  3. Level 1 dash cluster to level 3
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2006, 06:28 PM
  4. Replacing level 2 cluster with level 3.
    By madmick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2006, 11:18 PM
  5. VS Level 1 to Level 3 Cluster Upgrade
    By Luv holdens guy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-02-2006, 01:28 PM
