Results 1 to 12 of 12
Thread: Series II VN, just will not start.
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    Chain Reaction Champion!
    Feb 2006
    North Tassie
    Default Series II VN, just will not start.
    Ok, so here's the problem:
    When trying to start the car it'll just wind over heaps, and not actually fire. It sounds like it wants to, but it just won't. A couple of times it has actually fired but it's spluttering heaps for about 3 seconds then it just dies.
    I've swapped the coil packs over from another VN that a mate has just sitting in his back yard. And that made no difference. So next on my list is the CAS. But I don't really want to have to replace only for it to not be the problem.
    What I want to know is, what are the chances of it being the CAS? What else could it be? And is it possible to do find out if it is the CAS for sure without having to take it to a mechanic?
    I just want my car going, I hate not being able to drive it...
    Thanks guys.
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    a mass/axe murderer by night
    :: hakhawk :: says:
    and a rabbit sometimes
    I'm only nice to one person per day. Today is not your day....
    Tomorrow doesn't look good either.
    God must love stupid people, He made so many.
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    It could be many things.
    First check that the fuel pump is working.
    If O.K. then check that the engine has spark.
    If the car has spark it will be doubtful that it is the CAS.
    If it doesnt it could be the DFI module or CAS.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Can you hear the fuel pump when you turn the ignition on and then off again?
    If no sound from the tank a gentle thump to the bottom of the tank may get it going.
    Have u checked for error codes?
    Feb 2006
    North Tassie
    The fuel pump is working, you can hear it perfectly when you turn the ignition on. It's was only just replaced 6 months ago!
    Error codes?? Nah, I haven't done that. I was fairly sure it was the coil packs, but that turned out to be wrong, so now I'm back to the drawing board....
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    :: hakhawk :: says:
    88GreenVN's Avatar
    Jun 2006
    Chances are its the CAS if you have tried a corepack/DFI unit. But you should see if you have any error codes
    missus (in more ways than one)
    Sep 2005
    get some water, and pour it onto the Crank angle sensor, (behing the largest(crank shaft) pully, wait 30 seconds and 99% it will start, very common problem
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by CSL
    This generally applys if you have been driving and the CAS is overheating
    Feb 2006
    North Tassie
    Well, when my VN first did it, it hadn't been driven for about 5 hours, (it was fine beforehand) So I guess that's ^^ not going to help??
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    :: hakhawk :: says:
    Garth's Avatar
    Garth is offline Your guess is as good as mine......
    not telling
    Space Invaders Champion!
    Oct 2002
    put hand on injectors and with a mate starting for the car you will feel the pulse, if there is no pulse, crank angle sensor.
    do that and get back to us
    i am the god of britany spears womanizer on just dance on the wii
    Feb 2006
    North Tassie
    Thanks Garth, I'll do that as soon as I get a chance.
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    :: hakhawk :: says:
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    i had the same issue,
    turned out to be coil packs
    the usual reasons for this are
    Crank angle sensor
    fuel pump
    ecu dead
    DFI/coil packs
    But you've tried all that,
    so do a self diag,
    get a paper clip, unfold it... and insert one end into the white wire socket thats located in the front passengerside under hte kick panel near the ecu, then connect the other end of hte paper clip to the black wire bridging the white and black, the engine light should now be flashing, it should flash say once, then a break then three times for code 13... tell us if it reports any codes
    '92 HSV VP GTS
    Apr 2005
    SE Queensland
    When i changed my leads once I didnt put the right ones back in the right places, and it done exactly what u mentioned. Got them around the right way and its all good.
  1. Smashing start to V8 Supercar series
    By Torquative in forum The Pub
    Last Post: 01-11-2007, 08:16 PM
  2. Replies: 0
    Last Post: 15-07-2006, 11:34 PM
  3. When exactly did series 2 VS start??
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2005, 05:00 PM
  4. bugger won't start (VP V6 Auto Series 1)
    By MagwynTheGrimVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2005, 10:32 AM
  5. Series 1 Vn - Won't Start
    By mephisto in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2004, 10:23 PM
