Results 1 to 18 of 18
Thread: American Series I 3.8... Any help?
    DrJay Guest
    Default American Series I 3.8... Any help?
    Hey guys I'm new here to let me introduce myself. My name is Jason, I'm 21 and live in America. I drive a 1993 Pontiac Bonneville with the supercharged Series I 3.8. I believe the same engine (minus supercharger) was in your VN-VS but I get conflicting answers on that.
    I'm on a quest to produce Americas fastest Series I 3.8. I've already invested about $10,000(USD) into the effort and have a very potent engine. The problem is that we do not sell performance parts for this engine here so everything has been custom costing time and excess money to be spent. My quest for parts has taken me all the way to Australia in the hopes that this engine caught on more there and performance parts would be available. I've been met with mild success in finding a company called Yella Terra which produces 1.72 rockers and their sister company Crow Cams which believes it has cams for it. Because I already have a custom cam I would like to find a larger ratio rockers than 1.72; 1.9 would be best. Performance cylinder heads would also be nice.
    Because I'm not sure exactly what car this engine would be found in the best I can provide is a way to determine if you're looking at a Buick Series I.
    On the Series I the valves are sequenced: Exhaust-Intake Exhaust-Intake Intake-Exhaust. Take note of the two intake valves next to each other on the last two cylinders. Because of this one of the exhaust ports is spaced further than the other two which makes it obvious when looking at the exhaust manifold/headers. The Series II and III (Ecotec to you I believe) has evenly spaced exhaust ports. This is an important difference and because of it Series II and III parts will not fit my engine. I also don't believe you got the supercharged version in the Series I. Our Series I has the Eaton M62 supercharger while the Series II has the Eaton M90. The M90 is a shorter yet thicker version and generally setup with the fuel lines running over the top of it.
    Any information you can provide in my quest for performance parts is appreciated even if all you can do is verify which cars carried this engine.
    Thank you
    Jason Humphrey
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Try F.I.T (Forced Induction Technologies). They have a lot of products for our S/C V6 (similar to the L67 you guys are running in the states) and they have a 1:9 roller along with a few other products. What sort of supercharger are you using?
    Cheer
    Selling FG G6E Turbo and buying a N/A Supra
    DrJay Guest
    I'm still sitting on the M62 using a 2.2" pulley. I want to retain the stock apearance as much as possible. Thanks, I'll check out F.I.T.
    Jason
    VZ Executive Wagon 2006 & VR Executive Sedan 1993
    May 2004
    Australia Victoria Geelong
    Hi DrJay Remember Me.
    VZ Executive Wagon 2006 Hot Red, 18" Genuine Holden Rims, Window Tint, Kenwood MP3 Deck, Satin Chrome Highlights, Chrome Exterior Highlights. My Ride Link
    VR Executive Sedan 1993, White, 15" Aftermarket SS Rims, Sony MP3 Deck. (Currently Being Restored) My Ride Link
    Baldric is offline The BOSS
    VE GTS M6
    Dec 2003
    you have posted this exact post on ls1.com, why are you posting here as well as you got all the answer from there then you cross paste here....???
    ___________________________________
    Car: 07 VE SSV 6LTR L98 A6
    Metalic Silver
    May 2004
    I'd say he's getting as much info as he can get before doing anything.
    DrJay Guest
    Quote Originally Posted by AussieHolden
    This is exactly the case. I'm sure there is somebody somewhere that knows a lot about these engines and their differences. By asking everyone possible I've found little bits that are different between the two already. Also most of my posts get one or two relevant responses, although generally very helpful and very much appreciated. I've contacted every company people have listed and only 1 (and its sister company) provides parts for my engine and its a very short list. Because of that my search continues...I appreciate the responses so far.
    Jason Humphrey
    May 2004
    You mentioned in a post in my forum that the newer model up you can get heaps of mods & parts for so why not sell yours and upgrade if it's being a headache for you.
    DrJay Guest
    Well its only a headache because its a project...if that makes sense. I want to do this so I have something different. Any monkey can get a common car with a common engine and grab parts from the store down the street to make it fast. I want something different.
    May 2004
    Well DrJay you sure have something different then Good Luck in Getting your parts.
    SUPERCHARGED VP COMMODORE
    Feb 2005
    Ipswich
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Dr Jay you've come to the right place. The Buick 3800 V6 was fitted to the VN-VR commodore here in Australia, the VS had a highly modified version called the "Ecotec".
    There are plenty of people and places here who can supply you with info and sources for parts. Yella Terra and Crow Cams make some of the best gear out there, I'm told FIT are the people to talk to for supercharging these engines, although I haven't gone down that road myself.
    All the best in your quest!
    Toyota Supra Turbo
    Dec 2005
    SE Suburbs, Victoria
    Welcome DrJay,
    i don't want to make anythings more confusing for you, but we have a few variations of the Buick V6 ourselves! (Not talking about the Ecotec)
    Series 1 VN V6: Had thermostat housing on back of the engine, and when fitting roller rockers different sized bolts to bolt then down. No bellmouth in throttle body.
    Series 2 VN, VP all, and VR all: is probably the engine your talking about, has thermostat on front of engine, and bellmouth in throttle body.
    You guys in the USA have way better intake manifolds on your engines, and the option of a supercharger!!!!! I'd love to buy a supercharger manifold from there, but am concerned that it wont fit, as the engines out there are generally front wheel drive and are mounted east/west instead of the conventional north/south!
    Adam
    1990 VN S1 V6 Calais (SOLD!)
    1996 Toyota Supra Turbo
    Aug 2004
    S.E. Melb
  15. #15
    VY SS
    May 2005
    SA
    Quote Originally Posted by geta
    guys, the threads 2 years old.... :/
    lol...........
    Cheers, Gaz
  16. #16
    VN Commodore
    Feb 2006
  17. #17
    s0sage's Avatar
    s0sage is offline Posting aimlessly ..
    MX6 - Turbo .... so flame me
    Mar 2005
    hahahhaahhahaa
    oh god thats funny
    i had to say something ...
    never late in a 3 0 .. uhhh ... intercooled turbo
    yes i drive an mx6 turbo ... its probably quicker than yours.
  18. #18
    VN-88's Avatar
    VN-88 is offline fiery red vn manual
    vn v6 s1 manual
    Aug 2005
    victoria , lakes entrance, u live there tell me!!
    i cant believe i just spent the time to read that wen i got down and was told its 2 years old. and i was gonna ask if he had pics. ohwell
    check my ride
    http://forums.justcommodores.com.au/...ad.php?t=16665
    and feel free to comment
  1. Hello from the US. Sorry for being American.
    By bigjoe in forum V6 Development And Modification
    Last Post: 30-01-2008, 01:33 PM
  2. American GM Supercharged
    By SSbeast in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-12-2007, 01:34 PM
  3. American Choppper to come down under
    By Julie in forum The Pub
    Last Post: 14-12-2006, 11:08 PM
  4. Family Guy V's American Dad
    By brownie82 in forum Jokes/Humour
    Last Post: 05-06-2006, 04:06 PM
  5. Brit's V American's
    By stretch in forum Jokes/Humour
    Last Post: 02-02-2004, 01:11 PM
