Results 1 to 11 of 11
Thread: For Farts Sake! TACHO
    Bundy_VN's Avatar
    Bundy_VN is offline VN Rev-Head
    VN Exec S2
    Aug 2005
    In the carport, under the bonnet.
    Angry For Farts Sake! TACHO
    Ive hooked my Speco Tacho up, and i've done it correctly and it works, but not if you put on the lights (including hi-beams) or sometimes when you use the brakes (it drops back to 0 revs). I know you're all sick of Tacho questions but I'm about this close to chucking the thing to the shithouse and I'd rather not. So if anyone has any ideas, please...
    The Garrett GT42R Turbo is bigger than most human heads and will suck in small children and animals if they get too close.
    Shortstuff's Avatar
    Shortstuff is offline Random
    1995 VR II V6 Wagon
    May 2006
    Could be a short somewhere. Is it wired up to illuminate when you turn the lights on? If it is, i'd start by looking at that wiring. Or you could bin it and get a L2/L3 cluster
    Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
    Aug 2004
    mine did the samem, its a poor earth or power supply. fix these and it shall be fine.
    Bundy_VN's Avatar
    VN Exec S2
    Aug 2005
    Yeah i've changed the Earth and its still being difficult, it's gotta be the power supply, I'll have another look tomorrow after work. If all else fails then i'll get the L2 or L3 Cluster and find something to cover the holes in the Steering Column. Thanks anyway guys.
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    Well i was having trouble with power suply. I ended up running the wires to the cigarette lighter. I used the earth and power from the cigarette lighter and also got the tacho light from the cigarette lighter aswell. Worked a treat for me.
    Australia. Love it or leave it
    Bundy_VN's Avatar
    VN Exec S2
    Aug 2005
    Hmmm, sounds like an idea, I dont smoke or have little annoying neons using it so it should be good. Thanks man.
    Apr 2006
    canberra
    I can still use my cigarette lighter if i want. it still works. I just taped into the wires. I just thought the cigarette lighter would be the easyest because it has power earth and light all in one place. If you try it let us know how u go.
    Bundy_VN's Avatar
    VN Exec S2
    Aug 2005
    K, I'll give it a try after work tomorrow. Also while I'm here, you got any idea why my console (including dash all the way along) creaks when you push it? Its not affecting the ride in anyway, its just a bitch when you lean on it.
    Apr 2006
    canberra
    Wouldnt have a clue but mine does it aswell. Im sure its not an uncommon problem.
    VP Exec
    May 2006
    sounds strange, sounds like an earth problem, i got a speco tacho a little while ago and the lights on it dont work at all
    VL, VH V8 wag, Zook Vitara.
    Apr 2005
    Ardlethan, NSW
    haha the creaks and what not are standard on commodores aren't they?...
    Need some parts for my VH 253:
    Green standard steering wheel...Green lower B-pillar covers.
    Green sunglasses holder/lower dash bits...Air-con and assorted engine bay parts.
    PM with any info.
  1. VN Tacho-Less Dash To Tacho
    By Evman in forum General Discussion
    Last Post: 01-03-2008, 08:32 PM
  2. Dash with tacho fit into dash w/out tacho and work????
    By Jamie_87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2007, 09:21 PM
  3. Holden, time for a new ad, for god's sake
    By karlos_1984 in forum The Pub
    Last Post: 10-05-2007, 08:39 AM
  4. FOR GOD"S SAKE SUMBODY BUY THIS 7hrs left!!
    By VksupaNoob in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-08-2005, 10:27 PM
  5. engine farts, then cuts out...
    By MY_95_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-01-2005, 03:48 PM
