TOok my vpv6 for a drive today and it started to smell like something was burning. Got it home and there was F***ING coolant everywhere. There has been a bit of steam i guess in the mornings coming out of the exhaust. Just had my trans coolant lines done but they seem fine..I just put a cat back system on it and since then (yesterday) its been a bit harder to start but seems to run fine. I pulled the rad cap off when it was not running and it bubble up, went out then and pulled it off again and now i cant see any coolant in the rad at all???? Anyone got any answers???
Thanks for any help in advance!!!!![]()
STEP 1: Find leak.Originally Posted by juice
STEP 2: Fix leak.
Although if it has been running hot recently, your thermostat could be stuck closed, this can cause coolant to overflow from the plastic reservoir.
So u dont think its a head gasket??
sounds more like a leak than a gasket,
how long was it running hot for? be careful you didnt cook the heads
could be thermostat, in the overflow tank, did you remove the cap (plastic cap)
was it pressurised??? check all your hoses might be thermostat aswell
I only drove for about 5-10 minutes i cant remmeber for sure if the overflow tank pressurised or not been stressn to much about the whole thing just got it regod friday! Now i think about it more the temp gauge didnt even move from normal the smell alerted me more than any thing!
check your radiator (overflow on s1) cap, as its very comon for them to play up
nah not cap ,but thanks
If you've got coolant in the engine bay, it's coming from somewhere right? If it's not getting particularly hot, that suggests that it's most likely a leak. Go hunt it down! I reccomend checking hose clamps, if they're too loose they'll leak, if they're too tight they'll damage the hose, which will leak. Also, you could try running it with the bonnet up and watch (carefully) where the coolant is coming from.
Found leak its coming from the water pump(looks to be from the bottom bolt)
does this mean for sure it stuffed or can it just be lose??
water pumps by their very design are supposed to wear out. a badly working (loose) water pump is a very bad thing for the motor. so its either 100% or 0%.
by yuor description .. your water pump is hovering around the 0% mark .. give or take a few 0%'s.
change it mate, they're a dime a dozen and take about 20minutes to DIY.
plenty of how-to's on this forum or if youd like a hard copy step by step, your local library will naturally have a copy of a gregories repair manual for vn/vp commys and water pumps are well covered.
never late in a 3 0 .. uhhh ... intercooled turbo
yes i drive an mx6 turbo ... its probably quicker than yours.
sounds like the platic spacer thingo mabo has died. They are like a $5 part and take a hole of 5 miuntes to replace. Been there done that.
- OWA650 -
"Blown Vr wagon, 275hp at the wheels.. Much more to come in the near future!"
Do i really need use a torque wrentch or can i get away with out one??
you can get away without it. Just nice and firm dont over tighten.
- OWA650 -
