Results 1 to 21 of 21
Thread: vp wagon twin turbo
    vp vactioner wagon
    Mar 2006
    Default vp wagon twin turbo
    hey guys ive got a vp wagon at the moment
    im thinkin about twin turbo's are i dont think it would be that hard to do, and if i run small boost engine should handle it
    they will b 2 small turbos what do u guys think?
    i can do most of the work myself like mounting and making exhaust mani's etc
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    vp vactioner wagon
    Mar 2006
    thanks for that dude!
    just had a read though it not alot of info in that link regarding actual mods needed!
    would it be a good idea to run a surge tank? 2 fuel pumps? reg?
    is it hard to setup twins?
    has any1 got actual pictures of twins on a v6 in a engine bay?
    greenfoam seems to know what hes talkin about
    would you be able to post on pm me regards whats mods need to be done that your aware of?
    chhers guys thanks
    TT Supra/HZ Ute.
    Apr 2006
    Needed for buick:
    upgrade injectors/fuel pump
    2 bar sensor
    manifolds
    turbos (duh)
    wastegates
    boost controller
    intercooler and plumbing
    run oil lines for turbos
    connect dump pipes to zorst
    tune (major part)
    VP WAGON V6
    Mar 2006
    i suggest you go single. Its actualy alot easierr to fabricate and will savee you lots of money. Basically you can keep your stock drivers side manifold and run a cross over pipe around the back of the engine. Then make your own passenger side manifold to connect to th cross over pipe then to the turbo. That way you say a bit of money there. The other thing you will save on is oil lines. Thats a good $500 saving there. The only problem being that the turbo is mounted on the wrong side for the throttle body. So you many want to make a custom plenum OR cut the 90deg bend up and turn it the other way and weld it up or run a heap of excess cooler pipe. Ide suggest you start with about 6psi on a single turbo setup. Get it all tuned up and do a few kms before upping the boost to i say 10. That is about the limit for a stocko buick motor. Then ide grab another set of heads and get some head work done. You dont need to get them ported but a REALLY good clean up and a polish woulnt go astraigh. As well as some good vavles and springs. Then dive a bit deeper down into the engine. Even better would be to look into a COME racing strocker short motor. I think that they are about 4k without heads. But they are a 4.1l With fully worked block which you can get already with the low compression pistons and stuff into.
    I did a lot of research into this not to long ago, cause i WAS going to tubo my wagon. But ive decided against it now cause shes starting to get a bit of the old age disease.
    - OWA650 -
    "Blown Vr wagon, 275hp at the wheels.. Much more to come in the near future!"
    vp vactioner wagon
    Mar 2006
    thanks alot for that info mate if u have anymore info feel free to post it up good read i might do your idea as it seems alot easyer and both cylinder banks are still getting even amount of air so sounds like there no really great problem
    the only problem i see will be turbo lag beacause of the cooler pipes having to cross back over to get to the throttle body!
    ill see how i go
    VP WAGON V6
    Mar 2006
    Thats why i was going to make either a a custom inlet manifold or cut up the 90deg albow and turn it around. you could always put the turbo on the other side though. just not much room on that side. If you need to know anything just ask. Im not on here that much these days. Add me to msn if you like.
    the.might.laser@gmail.com
    Or send me a pm
    - OWA650 -
    vp vactioner wagon
    Mar 2006
    yeah might look at puttin turbo on onther side or getting a custom cooler
    vp manual wagon Guest
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    dude, move your battery to where the air box is, and move the air box where your battery was, so the air goes into the box, then across the front of the car into the cooler, then into the turbo after that into the TB...
    or move the battery to the boot, single turbo would be easier
    VP WAGON V6
    Mar 2006
    mate sorry to tell you this but thats not going to matter where the airbox is. Cause its still gota run to the turbo. Most people would either put a doose pipe on the turbo or a pod bolted straight on it. Either that or a pod run striaght to some form of cold air.
    Custom inlet manifold all the way. MAke the plenum a bit bigger and move the throttle body to the centre so the airflow is more constant at all inlet ports on the heads
    - OWA650 -
    mouce's Avatar
    mouce is offline Physics Geek
    VN V6 Series 1 Executive Sedan
    Jul 2005
    Why go for a single t/b? If you're going for a twin turb setup, why not run a twin t/b setup? There are twin t/b manifolds available for the Buick V6, or you could make your own.
    Have one turbo running into each t/b. That'd be nice.
    Gravity is proof that nature keeps getting us down.
    vp vactioner wagon
    Mar 2006
    im thinkin about goin single turbo now and placing the turbo on the drivers side then the pipe can run from turbo to intercooler then to throttle body no hassles!!
    vp vactioner wagon
    Mar 2006
  15. #15
    missus (in more ways than one)
    Sep 2005
    the thing about a turbo on the drivers side is the dump pipe wil hav to be quite small to fit between the main steering coupleing and the engine,
  16. #16
    VP Executive R-spec
    Jan 2005
    Just trying to think of the cheapest way out for you, Probably get a t04 s-trim sized turbo with like .60 compressor and .60ish turbine no more than .80. Weld upside down /chop cut the headers. Put the turbo on the passenger side, run a pipe from the drivers header around the front of the engine between the pulleys and the radiator with maybe a section of flexable exhaust pipe there infront of the engine so your pipes don't crack when they get hot. Dump pipe out the back of the passenger side. few bits of silicon joiner pipe stuff for your inlet, get a 2 bar map sensor and read read read how to tune it, intercooler would be good but still optional for low boostage
  17. #17
    vp vactioner wagon
    Mar 2006
    thanks for your reply mate
    how do i go about tuning it? do i get some1 to redo my ecu or what?
    thanks again ur a man with lots of info!
  18. #18
    VP Executive R-spec
    Jan 2005
    You'll have to tune it yourself, really that along with turbo selection are the two most difficult things, It will cost you heaps to have someone else do it. Even once you are good at tuning a NA car it could take you 20 re burns to get the turbo setup close enough to right, but you should get it safe to drive 1st go once you learn a bit about it. Read all the threads on here that have anything to do with memcals and eproms and tunerpro follow all the links and that should get you close to knowing all about it
  19. #19
    VP WAGON V6
    Mar 2006
    yeah. you couldnt put the turbo on the drivers side cause there is like no room down there. Except i suppose you could make your manifold with enough room to get ya dump pipe down there. Hmmm got me thinking again now. Im starting to think about turboing the wags again. But yeah, will need a full rebuild first.
    - OWA650 -
  20. #20
    vp vactioner wagon
    Mar 2006
    if i mount the turbo on the passenger side how bout i i run a pipe from the drivers side manifold under the engine? to the other manifold
    this seems like a good idea and the pipe will not be in front of the fan and engine in the engine bay! it will be under the engine then come back up to the other manifold turbo etc?
  21. #21
    VP Executive R-spec
    Jan 2005
    It will be behind the fan, and infront of the engine/belt, there is HEAPPS of room there go have a look before you do you best to complicate it
    Another way but it would be a tight fit, is remove the air con and stick the turbo near the firewall on the passenger side and run the crossover pipe just above the gearbox bell housing behind the engine, not sure if that will fit really but it might
    P.S Here's some pictures of a crazy under engine, through the manifold kinda setup:P
    Also this link is from FIT's website and is the famous turbo wagon, this is the kind of pipes you should aim for, but in a more budget way (and try make it possible to change spark plugs)
    http://www.v6supercharged.com.au/pics/cars_035.jpg
    Attached Thumbnails Attached Thumbnails vp wagon twin turbo-a5_12.jpg   vp wagon twin turbo-e7_12.jpg
  1. Super Charger, Twin Turbo Or Single Turbo On My Vx Need Suggestions
    By GMHG3N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-09-2009, 11:38 PM
  2. my TWIN TURBO VK wagon, and GTS kitted VL
    By BIT_SUS in forum VB - VC - VH - VK
    Last Post: 27-12-2006, 05:23 PM
  3. Twin Turbo
    By Majesticknights in forum V8 Development and Modification
    Last Post: 23-08-2006, 01:51 PM
  4. Twin Turbo better than Single Turbo?
    By Blue-Chip in forum V6 Development And Modification
    Last Post: 23-12-2005, 04:38 PM
  5. twin turbo ecotec, turbo selection?
    By jenkos_vl in forum V6 Development And Modification
    Last Post: 08-11-2005, 12:03 PM
