Results 1 to 11 of 11
Thread: Electric Aerial
    1991 Vn s2
    Feb 2005
    Warracknabeal
    Default Electric Aerial
    Hi, I have no electric aerail in my can and i have put all the calais dash buttons in my car ( cruze ect ). I have been told i will have to put a electric earial module in as well, does any one know if that will just plug into my car or will there be more to it than that?
    thanks.
    k§£¥
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Dont bother with the module. They often stuff up and then the aerial goes straight back down again... wont stay up.
    Also aftermarket aerials arent compatible with the VN module anyway, so you would need a genuine aerial... Grab an Aerpro aerial for less.
    Wire the aerial straight to the radio... When the radio is turned on, aerial goes up, radio is off, aerial goes down. But yeah the buttons wont work on your console to put it up and down, but they wont work proprerly with an aftermarket aerial anyway as I said before.
    But if you really want it to work...Genuine aerials are like $160 or something (Aftermarket Aerpro ones are between $90 and $99)
    Aerial modules you're lookin at $40-$50 from a wreckers or spare parts place normally. The wiring should be there already, it should be able to be plugged in inside your passenger side kick panel and up next to the glove box... Just a matter of locating the plug.
    VR Berlina auto s2
    Aug 2005
    the shire!
    yeah, my module was buggered, started acting all weird.
    So i just ray 12V to the switched and then to the aerial, totally bypassing the module
    works just fine.
    1991 Vn s2
    Feb 2005
    Warracknabeal
    Quote Originally Posted by 1991_Vn2nV
    Y will the aerpro ones not work with the modules?
    k§£¥
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by kasey375
    They're not a 100% perfect design as they cover more than 1 model so compatibility with the module is not perfect. They work with some model modules, not sure what ones. That 1 design is to suit VN/VP/VR/VS I think it is, and so it covers several different modules for those series. There were 2 or 3 different modules just for the VN. So the aerial works with some, not with others as there are differences in the modules. Doesnt work in any of the VN ones and I dont think it works for the VP ones either. Not sure about VR/VS.
    What will happen is it will be the same as having a faulty module. The aerial will go straight back down when you press for it to go up... as soon as u let go of the up button it will come down again. Same thing will happen when u start the car... It'll go up then straight back down.
    It does work sometimes. Maybe 2/10 times when you start the car it will work as it should. Seems to work more often when its cold outside, not sure why.
    missus (in more ways than one)
    Sep 2005
    funny that. my car is a s2 executive, but on the dash i ahve the antenna buttons, and i can hear it click when i do it, but nothing, how do i get into the gaurd to **** with the aerial and get it working again?? cheers
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Some prick snapped off my aerial so I disconnected it from the wiring and the stub just sits there. The motor still works a treat, just no aerial. You can get replacement centres and bands for not much. Might do that, but I'm told the guard has to come off to replace it.
    Life's Grouse in Frankston South!
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by fazz1977
    Its like $30 to replace the aerial mast... If ya dont wanna do it yourself just get JB Hi-Fi to do it... For probably $40 all up.
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by CSL
    Yeah either remove the guard, or the mud flap thing inside the wheel arch. If you can hear it click and it doesnt move at all, then its not the module or switches playing up. Either the wirings been cut before the aerial, or the aerial itself is completely stuffed, but normally when the motor has gone it still makes an awful noise trying to put the aerial up again...
    fazz1977's Avatar
    Aug 2005
    Cheers guys.
  1. Electric Aerial
    By numchuker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-04-2007, 08:36 PM
  2. electric aerial
    By knight97 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-03-2007, 02:49 PM
  3. electric aerial
    By Pete284 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2006, 07:33 PM
  4. electric aerial
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-04-2006, 10:42 PM
  5. electric aerial
    By fu2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-12-2005, 09:17 PM
