Results 1 to 5 of 5
Thread: VN Steering Scraping Sound
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Default VN Steering Scraping Sound
    Hey all..... noticed just recently.... That when i turn my steering weheel about 160Degress, its sounds to be scraping on something. I checked and its not the outer casing of the coloumb... any ideas? Its not an external sound, very internal... bearing or something?
    Thanx.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Bundy_VN's Avatar
    Bundy_VN is offline VN Rev-Head
    VN Exec S2
    Aug 2005
    In the carport, under the bonnet.
    Have you double checked the casing? Mine was doing that too and was shitting me but its all good now, WD-40!
    The Garrett GT42R Turbo is bigger than most human heads and will suck in small children and animals if they get too close.
    Morton's Avatar
    Fairstar the Funship
    May 2006
    They're just noisy... I've heard the vs did the same thing, so I wouldn't be surprised if it's just another one of those commodore quirks. Learn to love the noises your vn makes - they give it personality
    The 1972 HQ Kingswood
    91 VN SS 355
    Feb 2005
    WEST SUBS
    Just the old Plastic rubbing,try to adjust the s wheel,WD40 WOULD be good or try to see where it is making the noise.
    Cheers.
    * RVN 355 *
    May 2005
    .....SE Burbs
    Thanx for the replies guys/girls!
    Will check it out later....
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
  1. Steering column scraping and locking up
    By VHSLX3300 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-02-2012, 03:31 PM
  2. Water gushing sound coming from behind steering column
    By modcon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-09-2007, 11:50 AM
  3. does this sound like the comman vy power steering shudder ?
    By evil_monkey in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-09-2007, 11:02 PM
  4. scraping sound when shifting into Drive/Rev from Park
    By Loungefly in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-02-2007, 10:49 AM
  5. Scraping sound on take off, rear axle soggy
    By count ryxa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-11-2005, 02:30 PM
