Results 1 to 18 of 18
Thread: Callout Check
    VN
    Aug 2006
    Default Callout Check
    Hi all i just picked up a vn commodore i got it cheap becazz the last ppl could not get it started thay had a callout done on the car. thay done a code test found no foult codes and suspect fuel pump not enough pressure So when i got the car home i check fuel pump seens to be lots of pressure so now im lost the car turns over no probs and some times fires has spark but just wont go can any one help me with this im a s/dad and need my car to get my son to scholl and stuff so if any one can help me with this would be mint thanks
    253@7k is offline 300rwhp supra. yay.
    TT Supra/HZ Ute.
    Apr 2006
    Well an enine needs 3 things as you know, with spark there and obviously air getting in that leaves fuel. I would say that fuel is not getting somewhere. Possibly could be blocked injectors, could still be a fault with the fuel pump.
    My guess is some sort of fuel problem, somewhere to start anyway.
    HATER VP Guest
    VN
    Aug 2006
    Quote Originally Posted by slundy
    Thanks for the quick Reply
    I have 2 cars here one for parts and i change the hole injector set up and was still the same there was lots of fuel in the injectors so looks like the fuel is getting to the injectors but the injectors are not letting the fuel in or some thing
    PS:the car i have for parts the moter runs nice so it cant be blocked injectors
    and allso any one know if i can just change computers from one car to ather to test to see if it is that??
    TT Supra/HZ Ute.
    Apr 2006
    you could try that just so long as the computers were from the same make and model and same trans type.
    VN
    Aug 2006
    yep both the same cars same color and all lol if the car has a prob it wont stuff the computer im going to try will it? and it did come up with no code errors dont that mean the computer is ok???
    TT Supra/HZ Ute.
    Apr 2006
    I'm not too sure mate, what you described sounds wierd. if fuel is getting there then it sounds like a computer thing. I think its past me mate.
    VN
    Aug 2006
    Ok thanks for trying to help any ways
    TT Supra/HZ Ute.
    Apr 2006
    pandaman's Avatar
    pandaman is offline Aussie Muscle Fan
    VN Berlina 5.0 A4
    Feb 2006
    Quote Originally Posted by HATER VP
    Spark, Fuel and Compression
    Amen brother. Although in this case I think we can rule out compression as a problem, to lose enough compression on enough cylinders to stop it from starting would be fairly catastrophic and most likely would have been noticed.
    Fuel, ok so it has pressure at the fuel rail, and you've chucked in a set of spare injectors and it still aint happy, hmmm. Might be worth taking a few minutes to whip off the throttle body and make sure the bugger is clean, unlikely to stop it from starting but it can't hurt right? Once you've ensured that it's getting air and fuel then it's time to move on to spark.
    You say it has spark, have you checked the plugs on all cylinders? What condition are the plugs/leads/dizzy cap in? If they're all cool then things could become interesting.
    Like slundy said, if the cars are the same model and transmission type the computers will be interchangeable, and once again it can't hurt to try, but I'd be making sure all the basics were eliminated first.
    Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
    Luke Duke: You mean you're gonna make sweet love IN it.
    Beau Duke: Oh no, I'm gonna have sex with it.
    VN
    Aug 2006
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    VN series II custom :) and VZ exec
    May 2005
    Mildura
    have you checked power at the injectors? using a test light or a noid light, cos if you say there is fuel everywhere, but just not getting in i would suspect the power to the injectors, maybe check some fuses as well, if the cars are exact the same series i would even try diderent wiring loom,good luck anyways
    cheers, nick
    missus (in more ways than one)
    Sep 2005
    pour heaps of water over Crank angle semnsor (behing harmonic balancer(largest pully)) waitm half a minute and if all is good i.e fuel spark, then it will start
  15. #15
    VN
    Aug 2006
    Hey guys i got it going all it was it had shit in the coil pack plug
    thanks to all that tryed helping
  16. #16
    Aug 2005
    Queensland
  17. #17
    pandaman's Avatar
    VN Berlina 5.0 A4
    Feb 2006
    Awesome, cheap car in good running order! Hehehe, I've gotta stop posting while drunk, further up the page I suggested you check the dizzy cap which might have been a challenge considering V6's don't have one. Glad you got it working though.
  18. #18
    wes_v8's Avatar
    wes_v8 is offline WES_VN
    04 Vz Sv6 6 speed
    Jun 2005
    Maitland near Newcaslte N.S.W
    good job mate, nice 2 c u got it goin
  1. check this out
    By MUNTED6 in forum The Pub
    Last Post: 06-09-2007, 06:45 PM
  2. Check this out
    By GAMBLR in forum The Pub
    Last Post: 27-03-2007, 11:12 PM
  3. Can ya check for me.....
    By NORTI in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-09-2006, 07:04 PM
  4. Check this out
    By Kall911 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-08-2005, 09:32 AM
  5. Birthday Callout!
    By Troy711 in forum The Pub
    Last Post: 10-04-2004, 12:15 PM
