Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: What temp should my VP run at?
    VP S Model
    Apr 2005
    Default What temp should my VP run at?
    Hey,
    My VP's temp will sit at about 1/4 of the gauge when travelling along, but when stopped or moving very slowly, the temp will rise to half before the thermo fans kick in. Should the temp always rise to half...or should it sit a bit above 1/4 even when stopped or at lights etc?
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Mine never sits at half... always around a quarter.
    Make sure you use the good coolant not the cheap stuff in the VN/VP's. It has to be atleast to holden specs for the VN onwards and I personally use complete concentrate, no water.
    Other than that its probably just your thermostat or something... Check the coolant level is ok in the overflow bottle then check under your radiator cap to make sure the coolant is up to the cap underneath, if its not you have a blockage in your radiator/cooling system somewhere.
    holden007 is offline VRII
    Subaru Liberty
    Dec 2003
    I think thats pretty normal, when I stop or in traffic it goes to half way, fan kicks in and drops it back. Mines a VR but its pretty much the same as the VN engine.
    HATER VP Guest
    My VP sits on the first line on a average day, But does slowly creep up with the A/C on.
    AE86, VE2 SSV M6 UTE
    May 2004
    Mine runs cooler with the a/c on (due to the thermo fan always being on with the a/c):P
    Mine never gets passed half, and usually sits above 1/4 when driving and moves up to just under halfway when stopped....
    I used the holden coolant when i fixed my thermostat
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    mine sits at about 65-70deg..
    Buy a temp gauge, best money ever spent
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    YMY-88U's Avatar
    YMY-88U is offline Donating Member
    Project VH SL/E
    Jun 2005
    mine only ever sits at about half and the fan kicks in at about 3 quarters, there must be sumthing wrong there...
    5sp VN Executive1988, VX SS 6sp
    Apr 2006
    canberra
    My car ussaly sits on about 1/6 driving normaly then if im sitting at the lights on a hot day usally gets to around 1/4-1/2
    Australia. Love it or leave it
    YMY-88U's Avatar
    Project VH SL/E
    Jun 2005
    ok i think there is definently sumthing wrong with mine then if everyones sits on about a quarter or less, mine would only sit on that if it has been idling for 5 mins or less. i dont know what it could possibly be though, just this year i replaced both head gaskets and inlet manifold gaskets cos the block was blocked and it stopped the overheating problem... should i be running a colder thermostat or should the fan be kicking in earlier then at about 3/4s, if so how do i do that??
    92 vp berlina
    Sep 2004
    west aussie
    Jul 2006
    Quote Originally Posted by richie_cky
    Hey,
    Maybe you need to bleed your cooling system, I had the same problem and it worked for me.
    Apr 2006
    canberra
    Ive never had my car running hot enough for the fan to kick in. Maybe it doesnt even work i dono???
    1991_Vn2nV's Avatar
    Mar 2006
    My00 Wrx 240kwatw
    Apr 2005
  15. #15
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    a vn thermostat opens at 96c(about the second line or half way between) so anything at or below that is fine and if it dosent get to that maybe it isnt closeing.(i think there might be a 105c version as well?)
    13.3 1/4 exhaust only untuned!
  16. #16
    VP S Model
    Apr 2005
    Yeah, I have reversed flushed my radiator. Thermo fans work fine with the AC on. Fan seems to kick in a notch over half on the temp gauge. Thermostat was replaced about a year ago...would it need replacing again? Or maybe it was replaced with a dodgy one in the first place....but it was replaced with a new one from Holden dealership....u'd think it should be working fine?
    Only other thing I can think of is that the radiator is blocked. Any ideas on how much it would cost to had the radiator inspected/cleaned? I have bled the system to make sure there is no air. When I lift the radiator cap, the coolant is right up to the top, no air bubbles and green in colour. Radiator overflow bottle has plenty of water/coolant in it...
  17. #17
    Subaru Liberty
    Dec 2003
    check the Coolant temp. sensor (ECU)? mine had a similar problem and replace that sensor and it was back to normal. The part is $14 genuine.
  18. #18
    prince_dj666's Avatar
    prince_dj666 is offline hypo v6
    http://www.cardomain.com/ride/2112842/1
    Oct 2005
    QLD
    mine stays at 180 f dont know what is that in degrees. 220 with aircon on... and thats with fan on constantly
  19. #19
    fazz1977's Avatar
    fazz1977 is offline myspace.com/fazz_himself
    1992 VP Executive Wagon, L27 V6 3800
    Aug 2005
    Frankghanistan, Melbourne, VIC
    Mine runs at about 1/5 - 1/4, kicks up to just under half if I'm idling in traffic and the fan kicks in, drops it back to 1/4.
    It used to run at 1/2 and idle at lights at 8/10 until I had the thermostat and radiator done.
    Life's Grouse in Frankston South!
  20. #20
    flyen is offline bye bye
    Feb 2006
    normal driving it sits at 1/4 or under
    in peek hour traffic (idling) just under 1/2
    but thats in heavy traffic for over 30min or more
    and its never gone over 1/2 way
  21. #21
    VP S Model
    Apr 2005
    hmmmmmmmmmmmm....definatley think there is sumthing wrong with mine then. Will replace thermostat again, and get the radiator checked. I dont like the idea of my temp going past half, as it is tending to do now. When idling in traffic, it will shoot up to over half within 3 mins. I'm starting to think there must be a blockage of some sort or something, but i dont know....time will tell
  22. #22
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i run a 180 degrees thermostat and the temp gauge sits just above the bottom line when driving but it gets up to about 1/2 where the fan kicks in which drops it back to about 1/4. when idling and stuck in traffic. i've read that you should run a cooler thermostat to make power but a hotter thermostat for economy. mine seems to take an age to actually warm up but i suspect it probably a dicky sensor unit??? it's also due a flush and new coolant also for which i use prestone, GM spec????
    edit: for total peace of mind i would recomend getting an aftermarket temp gauge that has actual graduated temperature markings so youcan see the actual temp of the engine.
  23. #23
    VN Calais 5ltr
    Aug 2005
    vn2nv you shoudlent run straight coolant... its designed to be mixed for a reason....
  24. #24
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by lowrida56
    ummm no Maybe you should try reading the bottle one day buddy. It will tell you that maximum results come with 100% concentrate...However it can be mixed.
  25. #25
    VP S Model
    Apr 2005
    I read the Bottle of coolant I got from Holden.
    Said for optimum performace, mix with 50% water...
  1. Q's regarding Coolant Temp & Intake air temp sensor
    By Steven M in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2009, 05:08 PM
  2. What temp should my VP V6 run at?
    By locoman in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-10-2006, 04:35 PM
  3. Temp gauges
    By Unframed Mind in forum Electrical Wiring / Questions
    Last Post: 06-01-2006, 03:31 PM
  4. VP V8 temp
    By MasterOfReality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2004, 08:52 AM
