i have a vp v6 commodore 1992 auto,when you driving around the temp gauge sky rockets, and its very hard to start,
any ideas on what might be the problem?
Real cars don't power the front wheels, they lift them
if anyone has any thoughts of what the problem is or how to fix it , would be very thank ful
I had a 93 vp exec with similar problem it turned out to be stuffed radiator does your leak a bit of coolant as well?
We got rep back, yaaay!
It's the Crank Angle Sensor. Mine does the same thing. I'm not 100% sure but I think the harmonic balancer needs to be removed to replace it.
Noise elimination I call it. Find noise, eliminate it. That's all I ever seem to be doing.
Yes, with VN series II motor onwards, the harmonic balancer does need to be removed to get to the CAS. It's a relatively easy job to do, providing you have a gear puller or something similar to remove the harmonic balancer.Originally Posted by Stevob
:: hakhawk :: says:
im a geek by day
:: hakhawk :: says:
a mass/axe murderer by night
:: hakhawk :: says:
and a rabbit sometimesI'm only nice to one person per day. Today is not your day....
Tomorrow doesn't look good either.
God must love stupid people, He made so many.
what i did to check mine is drive around till its warm, then stop and turn the car off, try start it and it doesnt, then i got out with a spray bottle and cooled the crank angle sensor then tried again and it started, also i had to take my harmonic balancer off to get to my crank angle sensor and i have a series 1
u have to remove the harmonic balancer to get to the cas. but i didnt need a gear puller to get mine off it just slipped off
Adam
