Results 1 to 8 of 8
Thread: Irs cv joints
    vx ss
    Jul 2005
    Default Irs cv joints
    My cv joint in the passenger side of the diff has a broken boot and makes a bad vibration. i presume the cv joint needs replacing. On researching cv joints i noticed there are two types, ones that are built in ( ie axel needs replacing or welding etc) or exchangable ones ( parts are seperate and usually only the bearings bearing cages and boots need replacing)
    can anybody give me information on this problem, what type of cv joint the holden has and the cost involved if the repairs need to be done by a specialist.
    Thanks
    VN SII And VQ SII
    Sep 2005
    Melbourne VIC
    There pretty straight forward to do and 99% chance the joint its self doesn't need replacing, just the boot and a decent amount of grease will fix it. But if you are going to do it make sure you do all of them as if one has gone the rest ain't far behind. Through Holden the boots can be quite expensive but if you get them aftermarket you can usually get them for half the price, and rubbers rubber right! You proberbly could do it your self but applying the clamps will be hard without the tool needed, but other than that its an easy fix. If you like ill give you detailed instructions just let me know. If you get it done at a specialist you will prob. be looking at $100-$180, depending where you go.
    Please PM me if you know of any L67's complete with loom and ECU are for sale
    Y-Series Senator Signature
    Jan 2006
    Willall Racing
    yeah bout $200 to change all 4 boots dont pay more than that... genuine ones are crap IMO i got aftermarket ones that are hell better espec coz my car is lowered lots
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    Make sure you check them for wear before just changing boots.One day i was under my car changing the rear springs and all was fine,24hrs later it sounded like i blew the diff.Got under to see the drive shaft boot had split and i had lost all of my grease and there was grease all over my exhaust.
    The day before it was clean.The shaft was stuffed and not fixable.What im trying to say is they could get damaged really quickly so check it out properly.Easy fix though.I just got one from the wreckers and it wa sfine.
    VP Executive R-spec
    Jan 2005
    Mines been caked in mud for years:| with a broken boot. I tried to buy one from Holden but they said there is no more
    VT Clubby
    Oct 2004
    The shaft i didnt replace is cracked and still going strong.Dont know why the other died so fast.I did put very low springs in it at that time but only for a week.Maybe it was the different angle of the shaft that made the grease come out.
    vx ss
    Jul 2005
    cheers for all the help my boot has been broken for at least a year i think but the sound has not got worse. ( i originally thought it was the uni's) but i do have an after market boot with the grease will this still fix it. i dont think it vibrates that bad probably 3 on a scale to ten.
    Will the bearings need doing or should the boot and grease fix it
    VR SS 355 stroker
    Dec 2011
    I've been told my boots on my SS need replacing.. So seems like an easy job ... I hope
  1. Ball Joints
    By akallabeth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-01-2007, 03:58 PM
  2. ball joints
    By birdy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 01:51 PM
  3. Ball Joints
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-06-2006, 08:24 PM
  4. Uni Joints
    By tr3nt in forum The Pub
    Last Post: 10-10-2005, 12:36 PM
  5. Ball joints. How to???
    By LeojVS in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-04-2005, 08:00 PM
