Hey just a question. my air con dont work and i push the button in the console but the compressor dont kick in. there is power at the relay housing but no air con. any help would be apppreciated. thanx
Sounds like the system is out of gas !!!!!!!!!!!!!!
Yeah, thats identical to the symptoms my car has, and it's completely out of gas. If you get it regassed, make sure they use a UV dye so any leaks the system has can then be traced.
Whoever said 'There is no substitute for cubes' had obviously never heard of Jet power
sounds like out of gas as mentioned....
they have a low pressure switch.
